Question about Brother IntelliFAX 2800 Laser Fax
Fax not sending
Every other fax we send does not go through, and we get a transmission report that indicates "ng: poor line condition" -- is the problem on our end or the recievers? If our's, how do we fix it?
  • 2 more comments
  • theq111 Jan 09, 2008
    I have a good dial tone but keep getting the error message "poor line condition" and pages set is 00. any ideas on fixing are appreciated.
    Gary
    [email protected]
  • ray comcast Feb 11, 2008
    get poor line condition on all fax that are sent.
  • Anonymous Nov 17, 2008
    dont have usb line how can i hook up from phone line
  • CCRANFORD May 18, 2009
    WHEN SENDING A FAX IT DOES NOT GO THRU & THE TRANSMISSION REPORT COMES BACK NG: POOR LINE CONDITION BUT WE ARE RECEIVING FAXES OK
  • 186 Answers
It sounds like you have a problem with your phone line. If your machine has a reciever, pick it up or press the hook key. You want to listen to the dial tone. If there is any static in the line it will cause faxc problems. Also you can try disconnecting the fax and plugging in a standard phone into the wall jack. Make a phone call and aee if the line is clear or if there is static. If you do hear static in the line, first try replacing the phone line cord, from the wall to the fax, or phone. If that doesnt help then it is definatly a problem with the line and you must call the phone co. If the line is clear with the standard phone, and static with the fax reciever, or hook mode, then you may have a bad modem board in the fax. Let me know if I can be of further help! John
Posted on Sep 07, 2007
6ya staff
SOURCE:
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
When we try to fax, the transmission verification report reads NG: Poor Line Condition/Out of Memory
Is the fax on a dedicated phone line, or have are you sharing the line with another phone and perhaps a ADSL filter?
Hanging extra devices off of the same line as your Fax can cause the signal to weaken.
If you have extra devices hanging off one line, then remove all of them, then try to fax again.
Dec 08, 2009 | Brother MFC-8220 Fax
Dialing out to fax papers. Reaches the number but instead of taking the fax it prints out a report saying: transmission verification report -- NG: Poor line condition. I have never used this fax machine...
Perhaps you indeed have lots of interferences on your telephone line, or the recipient does.
It is also possible that the unit has been set for a different telephone line standard (for some other country) - check the manual for relevant settings. If you don't have a manual, go to Brother website and download one.
Nov 04, 2009 | Brother FAX-575 Plain Paper Thermal
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
OUT OF MEMORY
Brother Tech-Support told me to leave it unplugged over-night. I unplugged mine ant 12:00 pm and plugged it in at 9:00 am the next day and it still didn't work, maybe you have to leave it unplugged longer, try 24hrs.
Jul 15, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 2800 Laser Fax Logo
918 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
