Question about Danby DPAC8399 Air Conditioner
No Power Like everyone else the unit was working fine the 1st summer. Pulled it out again and nothing. It powered up for about 30 seconds then shut down. Now no power at all to the control panel. Is there a fuse link, or some kind of auto shut off I should be looking for? I can't say if it still blows hot and cold as I can't power up to find out.
  • grbuzzard Sep 05, 2007
    Yes there is power to the circuit and the unit. I did a meter test on the electrical connection to ensure no plug or cord issues.
  • 770 Answers
Did you check the drain switch ?? this will shut them dowbn as well?
Posted on May 20, 2008
My acer netbook 532h will not power on. just before problem the power on button stayed on and nothing happened; battery was pulled to turn unit off. unit has a blue light under the light bulb icon turn...
Two things to try first before we go further with the diagnosis:
1. Try to power up the netbook with the external hard drive disconnected & see if it will work.
2. Try powering up the netbook from the AC adapter only with the battery removed.
Nov 28, 2010 | Acer Computers & Internet
I have a 19 inch flx-1511b model monitor that powers on just fine and stays on with sound. but after 30 seconds or so the monitor shuts off. the sound still works and it has the blue power light on but...
www.youtube.com Lcd tv capacitor repair is what you search for , You have a bad capacitor , usually on the top board . on the left hand side. the video's will show you how to replace them and also how to tell a bad one , your problem is that a capacitor is bad and when it gets hot it cuts the power due to swelling.
Feb 26, 2010 | Element Electronics FLX1511B 15 in. LCD TV
Fan Failure Error
the temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Sep 28, 2009 | Eiki LC-XG210 Projector Multimedia...
My Garmin MAP 295 won't power up. Third time in 5 years.
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jul 01, 2009 | Garmin GPSMAP 295 GPS Receiver
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
RV refrigerator works fine on AC power. Burns for 30 seconds on gas power then shuts off.
tap on the gas valve with a wrench,not too hard but not too light about 10 times,the valve is probably sticky from not being used,re-light and see what happens.
May 10, 2009 | Dometic RM2652 Refrigerator
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Keeps turning off
Your power cord is cutting in and out. You either have a bad power cord or there is something wrong with the connection to the cigarette lighter. When the unit say "Running on battery - will turn off in 30 seconds" this mean that it has lost external power. This is by design so that when you shut off the engine external power is cut to the unit and that it will shut down.
It a shame that for the C330 Garmin decided to remove the LED light from the power cord that shows the power cord is connected correctly to the cigarette lighter.
Jan 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Danby DPAC8399 Air Conditioner Logo
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
