Ok let me clarify the problem, the motherboard is working, the proccessor fan is working and everything turns on but nothing will appear on the screen im not sure if its the power supply because i switch it to 115 volts and the procesor fan turns on but nothing will appear on the screen and then i put it to 225 volts and then the proccesor turns on for a while but nothing will appear on the screen im not sure if its beacause the proccesor, because it is a INTEL DUAL CORE PROCESSOR, please help me
Have you tried another monitor? Do you hear the hard drive spinning up and your keyboard lights blinking?Have you tried another monitor? Do you hear the hard drive spinning up and your keyboard lights blinking?
You can't post conmments that contain an email address.
it looks like your pc is overheating. try to remove your proccessor fan, put proccessor pasta on the top of your proccessor, put the fan back and check the proccessor fan speed inside bios setup.... try to turn on your pc only with mainboard, memory, and proccessor.... unhook everything else... see if it still freeze... hope this will help...
either your power suppply needs to be cleaned or the proccossor is bad only one way to find out put the cpu in another computer of the same type or put a good used in yours but first thak the memory out one at a time unless it dual memory moduals if after you take out one on it turns on then you need to replace the memory the memory can stop the proccessor from working bottom line test memory and the proccessor but be sure to use a hair dryer to blow out the dirt inside your computer and powersupply
windows is not booting high Temp.
problem with Cpu fan chaque proccessor fan it running or not. if it running refix the cpu fan . Clene & peste apply on it . it Reduce the temparatur of machine window Able to start booting, if Same issue than replace the cpu Fan,
your system shutsdown to save your hardware from damage due to hight temperature because the fan is not working. Make sure you connected everything right on your motherboard. to test if the fan is ok try putting it in another entrance on your motherboard, you can find at least two or three place to connect a fan on your board, if all fails check with a friends motherboard, if that fails replace your fans.
That is most likely the proccessor overheating and shutting down.
Remove the processor's heatsink and fan, clean off all the old thermal paste with alchohol and a cotton swab, you can use a piece of plastic like an old credit card to remove any stubbon thermal paste.
Reapply the thermal paste (about the size of a grain of rice is sufficient) and reattach the heatsink and fan then start the machine up again.
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Your motherboard has died .
No beep code explains it all .
LED lights and even fans spins only tells me that your getting power to the motherboard , but No beep code is crucial .
Every motherboard will beep once when your first turn on and beep once again before the Opertional System boots up .
Sorry again for your loss ...
