Question about Samsung YP-U2JQB MP3 Player
Battery replacement How do I replacement my battery. and what type do i have?
  • 80 Answers
Go to samsung type in the name of the mp3 you shoould get a bunch of results in one it should say something about shoping click on that and that should be it you can buy it and if you need instructions it should tell you in the samsung page. good luck
Posted on Sep 07, 2007
SOURCE:
I must replace the battery? What kind? And what is the warranty on the Solar powered led motion sensor security light ? Thanks
It is important to replace the battery with an identical type and that usually means taking the lamp apart to identify the battery type and specification.
If your lamp is a high quality type it might be possible to buy a replacement battery as a spare part, though that would usually be disproportionately expensive.
An older lamp might have a Ni-Cad type and replacing them with Ni-Metal hydride would be worthwhile but if they are a lithium type only replace with identical. Replacements for most types are available from Amazon or ebay or similar sites.
Jul 22, 2018 | The Home Security
I HAVE SONY WALKMAN NWD-B103F- BATTERY DOES NOT LAST FOR 10 MINUTES-AFTER CHARGING ON COMPUTER
The battery does not hold charge. It is weak. Replace it with same type number. Brand name of the battery isn't a matter, check its type number printed on it.
Jul 09, 2016 | Sony Walkman Audio Players & Recorders
Can I replace my 2010 Lexus 12V battery vented type with a regular battery
Surely the vented type is the regular battery?
To the best of my knowledge both the wet type battery and the gel type battery are both vented and interchangeable, though the gel battery is often considered a sealed type they do generally contain an array of valves to allow the escape of gas..
Both offer advantages over each other with the wet type battery being the traditional fitment for motor vehicles. Gel type batteries have a history of variable reliability with the main advantage being the danger of spilled acid is removed they can be fitted in positions a wet battery would be unsuitable for.
If in doubt refer to the battery manufacturer's application catalogue.
Feb 25, 2015 | Lexus Cars & Trucks
Replace cmos battery and case openning
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Dec 12, 2013 | ASUS CS5111-AP007
I have an intel g41 motherboard....every time i switchon d pc...it shows check cmos error and the time and date are set to defaluts
This error occurs when the BIOS battery is flat. Replace the BIOS battery, most motherboards use a lithium battery type CR2032, this is a coin size battery. Check the BIOS battery type used on your motherboard before you purchase the battery.
After replacing the battery go to the BIOS setting and set the Date & Time etc. and you will not have this CMOS error.
Aug 10, 2011 | Intel Motherboard
Low battery alert at start up. must always type
The only battery in a desktop PC is the CMOS battery. This is a 10c sized silver disc that is held in a plastic black clip on the Motherboard. It can be clipped out and easily replaced. they are 3.6v and somewhere like Radio Shack etc. will have them.
Jan 27, 2010 | Dell Dimension 8400 PC Desktop
Garmin gps III / internal battery replacement
March 2009 I replaced the solder type battery of my GPS III Plus with a battery holder (clip) that a “Basic CR or BR2032 Coin type battery”, without solder connections, that is, they simply clip into place. Replacement batteries can be purchased at less than a $1.00 of E-Bay.
Jul 07, 2008 | Garmin GPS
Samsung YP-U2JQB MP3 Player Logo
102 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
