Question about Samsung Digimax D53 Digital Camera
My Camera Won't Come On At All.
It WIll Just Show The Green Light And Cut Back Off.I'm Trying To Figure It Out Because I Really My Camera.
    Scholar:
  • 97 Answers
I have had this exact problem with this camera. I find it behaves much better with rechargeable batteries or oxyride disposables. The stupid part is that it is supplied with alkalines, which can't handle the power requirements of the camera. Even "High power" (eg duracell M3) alkalines are unlikely to work adequately.
Rechargeables will save money in the long run, anyway.
Posted on Nov 09, 2007
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
My LCD Sanyo tv won't show picture and the green
PLEASE CHECK CABAL LINE FIST. SEE THE TV BACK SIDE AND ADJUST UR CABAL JACK.OR HAVE ANY DVD PLAYER PLEASE ADJUST UR DVD JACK SEE UR TV PICTURE.IF SHOW UR PROBLEM SOLVE OR NOT SHOW UR TV PANEL PROBLEM.
Dec 27, 2012 | Televison & Video
I'm trying to hook up a Camera back up system. I need to tap into the power for the back up light to power the camera. My problem is I can not figure out which wire powers the back up lights.
Hi, the backup light power is on the white wire with a light green stripe. You can tap it on either side (left or right tail).
Thanks for using FixYa.
Feb 01, 2011 | 2005 Jeep Grand Cherokee
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
I am trying to figure out proper wiring for 95 raodmaster stereo in atempt to correct botched job from previuos owner.Back speakers were cut and hot wire for power attenna!
Constant 12v + orange
Switched 12v + yellow
Ground Black/white
illumination grey/black
dimmer brown/white
antenna trigger dark green
left front speaker + tan
left front - grey
right front + light green
right front - dark green
left rear + brown
left rear - yellow
right rear + dark blue
right rear - light blue
Apr 04, 2010 | 1995 Buick Roadmaster
Camera will not power up. I recharged the battery and the charger shows a green light but camera won't turn on. Thanks
How old are the batteries? They really aren't meant to last more than a year or two. Dieing batteries may show green in the charger, but only hold the charge momentarily.
Aug 03, 2008 | Canon Cameras
Photo problem. sony cyber-shot 10.1 MP silver touch screen
Take out memory stick, connect camera with PC, go to Removable Disk, go to folder and copy that picture. Simple !
Jul 31, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Ethernet
The internet cable fed to your modem by your ISP if faulty.
Jun 29, 2008 | Computers & Internet
ViviCam
Do you have a viewfinder and a screen? The screen won;t show anything if you have the viewfinder turned on.
Jun 18, 2008 | Vivitar ViviCam 5100 Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
$100 is hardly expensive, and at that cost it would be cheaper to replace it than have it repaired. In future, keep it on the neck strap.
Mar 15, 2017 | Cameras
Samsung Digimax D53 Digital Camera Logo
24 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Terry Leonard
Terry Leonard
Are you a Samsung Camera Expert? Answer questions, earn points and help others
