By stutter you presumably mean it misfires? Most hesitations and misfires by far are caused by an ignition problem - low output from coils, worn spark plugs and suchlike though bad injectors or low fuel pressure can play a part.
Every diagnostic process should begin with a thorough visual underbonnet inspection and a code read.
repairpal.com > Problems > Buick > Park Avenue Buick Park Avenue Engine Stalling Due to Mass Air Flow/Crankshift Position Sensor Failure. This is a verified ... 1997 Buick Park Avenue- 3.8L V6160,000Visitor. Engine stalls ... car runs then stalls and won't start for thirty minutes. Upvote (36).
Buick stuttering Questions & Answers - Fixya
www.fixya.com > Forum > Tags > stuttering 94 Buick Park Avenue that stutters under a light load I have a 94 Buick Park Avenuethat ... Buick Century 97 runs rough and stutters when cold and gas applie Engine runs rough ... I have a 1994 buick lesabre it starts ok but stutters and stalls.
yes you reLly are a dj, only doesn't know how you have to maintain simple gear , pioneer amp a assume?
You don't need new tt, just knowledge and being a 'dj' , search and finf on google
replace the distributor kap and rotor. you can test this.if you have a wife ask for her nailpolich. do that on the cracks few layers.and try see if error is gone. if yes replace bolt kap and rotor. ( oh any color will do haha)
well to be honoust, it would be the best, but not price wise. I can't help you, only let a pro look at it with you by your side. It turnds and grabs the side and yesterdat i reard that loose components can be installed......
I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet.
He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
