The backup program only came installed in the Pro version. In the Home version you need to install it from the original operating system CD. Put the CD in the drive. Goto Start, Run and type (CD Drive):\valueadd\msft\ntbackup. This will install the backup program.
If you still have an XP CD then go here for the instructions on how to use windows back-up.
http://www.microsoft.com/windowsxp/using/setup/learnmore/bott_03july14.mspx
If not then Acronis true image is probably one of the best to use to back everything up with and you can DL the trial here:http://www.acronis.com/homecomputing/download/trueimage/
ANd for a totally free one that works good but is just a little less user friendly you can get Drive Image here:http://www.runtime.org/driveimage-xml.htm
Hope this helps.
Determine how much space you need.
The first step in backing up your hard drive is to figure out how much space you will need to back up all of your files.
You can do this in a couple of ways.
Find out how large the hard drive is on your computer first to see if you can back up the whole thing. Click on "My Computer," right-click the "C" drive and select "Properties."
This shows the approximate size of your hard drive, how much space is actually taken, plus the space used by your operating system.
If your hard drive size is manageable (the space actually taken), back up the whole thing.
Your second option is to create a file called "Backup" and copy all of your important files into it.
Right-click on the folder once everything is copied over and choose "Properties" to find out the size of the folder.
This is how much space you will need to back up your important files only.
Choose a backup method. Choose either an external hard drive, data disks (CDs, for example) or use an online backup service.
There are advantages and disadvantages to all.
An external drive is convenient because you can plug it into other computers and immediately transfer or copy files without needing the Internet or having to worry at all about security.
However you have to carry the drive with you and always face the remote possibility that both your computer and the hard drive would break.
Data disks provide the same advantages and disadvantages as external hard drives: portability, but the possibility of theft or breakage.
You can also use an online backup service.
These services range in price depending on the amount of storage.
The advantage of an online service is that you can access your files from anywhere there is Internet, and it is generally cheaper, especially for small amounts of service.
Also, you don't need to carry or store another piece of equipment.
The disadvantage is your backup is stored on the service's external server, so security is a potential issue.
Back up your files. Once you have chosen your method of backup, do not forget the most important step: back up your files.
For external media, go into "My Computer" and double-click the "C" drive to open it.
Select all the files if backing up your entire hard drive, or select your "Backup" folder if just backing up your important files.
Holding your "CTRL" key, drag your selected files to your back up source, either your external hard drive or data disk drive.
Release your mouse button and "CTRL" key and allow the files to be copied onto your backup media.
or http://download.cnet.com/easeus-todo-backup-free/3000-2242_4-10964460.html Its Disk Cloning feature will help you migrate your operating system and data to a new hard disk when it's time to replace the old one
click start control panel system security tab in that back up my computer in windows7or click start all programs accessories system tools you should see back up in xp
depending which operating sytem you are using this may vary
click start control panel you should see system security tab in that back up then windows will ask for a back up DESTINATION location you can select either dvd or another device in windows7
click start all programs accessories system tools you should see back up in xp after the back up finishes windows will tell you your computer back up was successfull also you could right click on the back up file select properties this will tell you how many GB were used
hope this helps
The solution was good, but the problem is that I don't have the XP CD.
