Question about Marantz CD-48 CD Player
Marantz CD48 - CD spins backwards
Although I am a qualified electronics engineer,I have not been able to solve this problem on my Marantz CD 48 player.When a CD is inserted,the unit does not read the CD but instead it spins counter clockwise at very high speed. When switched on,the Display shows..Read > No Disc and then the CD rotates counter clockwise.No functions work at this stage and the power has to be switched off and on again to eject the disc.The Laser does not seem to be switching on either. Could someone help me solve this problem please?
  • Gordon Sep 04, 2012
    Thank you Seamus377.Your solution solved my problem exactly.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 99 Answers
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Posted on Sep 01, 2012
Is the master clock generator oscillating? Probably a 16 ish MHz crystal.
Posted on Dec 04, 2007
SOURCE:
After a brief power outage, my Marantz receiver, model SR-48, is stuck in standby mode. Tried unplugging it, but to no avail. What do I have to do to reset it? No owner's manual found online.
I think your radio is as much computer as radio. Computers are everywhere and contain delicate CMOS circuitry - easily damaged by a power surge such as often accompanies a power outage.
Surge protectors should be used to provide a measure of protection, although it is possible a software fault has been caused by the sudden interruption of supply.
May 07, 2018 | Marantz Audio Players & Recorders
I Have a Marantz CD48. I have replaced the laser unit. But CD is still not spinning and cd is not being read.
Check power plug wires and replace the fuse and check if the unit has fuse on the rear and replace it.
Jan 11, 2018 | Marantz Audio Players & Recorders
LOOKING FOR BELTS
Although this say 'vintage', try them. They may well be able to do by size rather than model.
Vintage Electronics Powered by Network Solutions
Dec 09, 2015 | Marantz PMD371 5-Disc CD Changer
CC-65 CD changer. Why does it load disks, but does not play them?
unless you are a qualified technician you are unlikely to be able to fix the unit, I imagine it will require advanced technical knowledge
Jul 18, 2015 | Marantz Audio Players & Recorders
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
I have a MARANTZ ARCH and it has just started to develop problems with the cd draw it opens and closes fast a few times then will open and close normal also the flap will fold down draw will come out the...
If the system is less than 3 years you still qualify for manufacture warranty, usually it is accumulated dust, you can open the system's case and clean with a dust cleaner can, you can buy at staples, best buy, radioshack, and any major store.
If dust is not the problem than is an electronic problem, there is one electronic component that is in charge of closing the flap at xx speed. If that one is burnt out you can replace it, I recommend you have an electrician look at the circuit. or Contact the Marantz for warranty at: http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx
May 24, 2011 | Marantz Arch 1.0 Shelf System
Disc inserts but doesn't spin
HI, this is a possible spin motor issue,. try to reset the main board by unplugging the unit for five minutes. If the unit continues to not spin the disk, when inserted, this will confirm the damage to the spin motor. It must be replaced, in this case, by the manufacturer or a local electronics repair depot.
Oct 21, 2009 | Marantz Audio Players & Recorders
Turntable spinning backwards
Defective control PC board. take in for service
May 06, 2008 | Audio Players & Recorders
Sound only coming through one channel
You may possibly have a fault with the RED RCA output plug on your CD possibly a loose wire on the internal side or a faulty plug altogether. Try plugging it into another stereo and see if the problem replicates itself.... if so then i am sure that will be the case.
Jan 25, 2008 | Marantz CD-48 CD Player
If it is a direct drive TT then it uses some electronic circuitry to control speed and it sounds like that circuit is having a problem. Possibly the actual driver IC for the TT motor has gone bad. Good luck.
Feb 13, 2007 | Vestax Pdx2000 Direct Drive Turntable...
680 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
