hello...yes...we same a request and clarification of mr/mss>>micromend what is it or what is the ERROR?..Thanks..^_^hello...yes...we same a request and clarification of mr/mss>>micromend what is it or what is the ERROR?..Thanks..^_^
Hello ,
This is Registry or domaged entry in any application can cause this problem so Better your Registry optimizer like CCleaner
Hope it will help :)
Automate the above task using this utility This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
Pasos para hacer bootear Windows:
-apagar el equipo
-encenderlo y presionar constantemente la tecla F1 para entrar al BIOS.
-dentro del BIOS nos vamos al sub-men? Startup y lo configuramos de la siguiente forma:
***Startup***
*Primary Boot Sequence
*CSM: [Enable]
*Boot Mode: [Auto]
*Boot Priority: [UEFI First]
*Quick Boot: [Enable]
*Boot up Num-lock Status: [On]
add image in the mode perfect.
Some program is trying load. Try Start > Run > type MSConfig > Startup > Look for and uncheck undesired software. This will stop any annoying software from loading when windows starts.
voldown, central key and reset botom at the same time, then text
appear, choose number 1 for restore manufacturer default pressing volup
or 2 for restore munufacturer default and format moviMand pressing
voldown and wait a few seconds.
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
A defective hard disk drive
The CMOS drive settings (parameters) are not correct for the boot device
sounds like your cmos 3 volt battery is dead and needs replaced. its a very small coin size battery located/hidden inside the laptop. you will have to google the placement or just find it.
What is the error?
