Question about Kodak EasyShare DX4530 Digital Camera
Faulty camera Turned on camera , and theres a black ink like mark under LCD screen. None of the features on the camera now work.When camera is of you can still see this mark very faintly LCD screen is white when turned on , black mark takes up left side of screen and is very very slowly getting bigger. Could this possably be a leak of some sort? Thanx Matt
    Sergeant:
  • 274 Answers
LCD is damaged and needs to be replaced. The cost of replacing is less than buying a new camera. If they charge more than 50 of the cost buy a new camera.
Posted on Sep 16, 2007
  • Jerry Hess Sep 24, 2007
    How can you rate this as "almost here"? It's solved...LCD is "BROKEN".
Hdc-1209er screen failing can it be repaired
Roger, the LCD screen can be replaced and they are listed on E-bay under camera parts under your make and model camera.
Jan 16, 2013 | Hitachi Cameras
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Dear Adrienne,First make sure that the black ink is not empty. If you are sure the black ink is full enough you need to check the print head condition. The print head may be clogged or faulty.
To fix the clogged print head,please perform the following step:
  • Print the nozzle check pattern, access the following menu on LCD: Menu>Maintenance>Nozzle Check. The good nozzle pattern should like below sample image.
  • If the print head nozzle missing some color (i.e Black) the perform print head cleaning: Menu>Maintenance>Cleaning. Then print the nozzle check pattern again. Note: you may repeat this step up to 3 times.
  • If the problem still remain,then you should perform Deep Cleaning: Menu>Maintenance>Deep Cleaning.
If you have perform the above steps but the problem still the same,please check whether the black nozzle missing partially or totally. The faulty Purge Unit (ink pump) may cause the same problem. I mean the purge unit does not work properly so the ink cannot flow. Good luck :)
Regards,Xanda
Oct 05, 2011 | Office Equipment & Supplies
My Canon EOS Rebel T2i EF-S 18-55 IS Kit 18MP Digital SLR 4462B003 USA Model will not come on. What is the possible problem?
It's probably coming on but the button has been pushed to activate the viewfinder so all information gose there and the LCD screen remains black OR because this camera has an interesting feature just under the viewfinder that scenes the photographer looking into the viewfinder automatically shuts off the rear LCD screen. If this sensor is blacked then the LCD screen will not come on.
May 12, 2011 | Canon EOS 550D EOS REBEL T2i Digital...
The screen on my camera stays black after the camera is turned on. The lens cover is open. If I take a picture it will just be black.
If you transfer the picture to your computer and you get a black image then your "lens" is faulty - actually a cmos based receiver.
If the photo is ok - then the back LCD screen is at fault.
Either way, it needs fixed and if under guarantee contact the manufacturer and ask for a replacement, or take it back to the store you got it from.
Or if out of warranty you will need to buy a new one I am afraid.
If you have some technical skills you could look on eBay for another broken one of the same model as yours and put the two together to get a working camera.
Jan 07, 2011 | Cameras
LCD Screen not working, but camera still takes pictures
Looks like the contacts of the LCD of your camera are loose. Be advised that this repair would require you to take it apart and may vvoid your warranty. If there are no faulty contacts then you will have to replace the LCD screen. Should cost you around 100-150$
Nov 14, 2008 | Canon PowerShot A640 Digital Camera
Repair screen? is it possible? and where in uk?
i lost the cd to install the camera so i can download picture. What can i do
Mar 16, 2008 | Vivitar ViviCam 5386 Digital Camera
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
106 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
