Question about Motorola Mobility RAZR V3i Cellular Phone
Bluetooth connectivity My Motorola V3i is unable to connect to bluetooth. It gives me 60seconds which is too short a time to have done anything.
    Problem Solver:
  • 30 Answers
Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device. My question for you is, what kind of device are you trying to connect to?
Posted on Sep 10, 2007
SOURCE:
I need to connect a bluetooth to my razr
Do you need to connect a bluetooth headset , or do you need to start bluetooth file transfers?
In either case, to activate blue tooth on the RAZR V3i go to settings>connections>bluetooth (May appear as "bluetooth link") > hands free> look for device. The Razr will scan for other bluetooth devices. If you need to send files over bluetooth, turn on the blue tooth antenna, and navigate to the files you wish to send. Press the menu button, and press "copy" and select the device you wish to send it to in the devices list. If there is no device, or the device you with to send it to is not in the list, press "look for devices".
Mar 28, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth
What you need to do is take your phone to a service center and have them reflash the firmware, that will correct the bluetooth problem.
Jan 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
My computer unable to readmy motorella v3
you have got 3 option
1. bluetooth enable phone and computer, make the pair and thats all
2. a seperate bluetooth adopter which connect to the computer and make pair to your phone wirelessly.
3....a software and cable for your phone. load the software in to computer and connect your phone to the computer via cable.
thanks
khan, south africa
May 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
BLUETOOTH INSTALATION
Be sure to follow every step to setting up and connecting a bluetooth device to your phone.
http://www.askdavetaylor.com/cant_pair_bluetooth_headset_with_motorola_razr_phone.html
Apr 08, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth won't power on
when you power on bluetooth and do nothing within 60 seconds it does not work and then you will have to apply "find me"
May 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth
from ur bluetooth link open device history and select the blue device and delect, some of the devices.
Feb 28, 2008 | Motorola Mobility RAZR V3x Cellular Phone
V3i as modem
yep simply attach the cable start your motorola ponetools and tada you are done
Nov 18, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth failure
pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
Jul 19, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
128 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
