Question about Abit KV8 Pro Motherboard
Does not recognise hard drive
I have a KV8 PRO that has been happily running with a Hitachi diskstar as a SATA drive for over two years. Without any hardware or software changes it now comes up with the missing or corrupt SYSTEM/CONFIG message. When you try to repair or reinstall XP it no longer recognises that a hard disk exists. Any clues?
You need to go on BIOS and and place the SATA as first boot device. Just extra info.
Posted on Aug 15, 2008
  • 231 Answers
Hi, this problem sounds to me like you have a drive failure, it could be that the active partition is corrupted, if so you need to run a bootable repair program. you can purchase repair disks on ebay [in computers & IT software] for about $6.00. At that cost it is worth a try. The other options are run the XP repair console from the second prompt and see if that will do the trick, last option and only in desperation = replace the drive. Regards mistyman
Posted on Sep 05, 2007
What does code 7f mean on kv8 pro
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code:
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
May 23, 2014 | Abit KV8 Pro Motherboard
Hi wont to now if this model is work on macbook pro hitachi hts545050b9a300
if your mcbook pro hitachi is sata supported,sata is a kind of cable connector from your hdd to motherboard ,check your cable connector in your mcbook if sata.
May 16, 2011 | Hitachi (hts545050b9a300) 500 GB SATA Hard...
No sata in bios
Update the firmware:
Mar 07, 2011 | Abit KV8 Pro Motherboard
I have K8V-MX motherboard. I am planning to buy a 1TB SATA HDD Will this support ? Thanks! Madhusudan
Your model KV8-MX motherboard does not have a SATA controller.
To install a 1Tb SATA hard drive you need to install a PCI SATA controller and then connect the SATA hard drive to this controller board.
Aug 21, 2010 | ASUS K8V-MX Motherboard
1st Gen Macbook Pro Hard Drive Clicking or
Nov 08, 2009 | Apple MacBook Pro Laptop Computer with...
I have recently bought a HITACHI SIMPLE DRIVE 1.0 TB DATA STORAGE and it had no disk and no manuel and i cant seem to install. I also searched the internet and have found no software to help me...any...
if its an external hard drive then and you want to install the hard drive on your computer, you have to install the BIOS on it and then install the OS you want on it also. this will make the hard drive able to be used by your computer.
if its a portable hard drive, then just use the control panel of your computer to find the device, normally any plug-n-play device is usually recognised and installed automatically by your computer.
Aug 15, 2009 | Hitachi 120 GIGABYTE SATA MOBILE STORAGE...
Hitachi Desk star 500GB SATA drive
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Installing Hitachi P7K500 Sata Hard Drive
Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Dec 31, 2008 | Sprint Hitachi P300 Cellular Phone
SATA Drivers for Hitachi HDD
Is there a BIOS setting to temporarily put the SATA controller into legacy mode? XP would then think it's an IDE drive. Then, after installing XP, install the drivers from the motherboard CD, then go back into the BIOS and turn off legacy mode.
Jan 13, 2008 | Computers & Internet
Motherboard does not recognise new SATA hard drive
Is your board an ABIT? If so then here is the link to select your motherboard and download the latest BIOS. Make sure to read the web sites instructions on how to update your BIOS. Let me know if you still have issues.
Dec 30, 2007 | Abit KV8 Pro Motherboard
Abit KV8 Pro Motherboard Logo
142 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
