All Honda manual transaxles use the Honda Manual Transmission Fluid (MTF) as the original factory fill. This oil is similar to a 10W-30 or 10W-40 viscosity engine oil, and this oil can be substituted temporarily. However, the manufacturer recommends the use of their MTF when changing the fluid.
Level Check
The transaxle fluid should be changed every 90,000 miles (144,000 km) or 6 years under normal driving conditions. In severe driving conditions the fluid should be changed every 30,000 miles (48,000 km) or every 2 years, whichever occurs first.
Make sure the vehicle is on a level surface. If the vehicle is raised, make sure the vehicle is safely supported and level
NOTE: Do not confuse the drain plug with the fill plug. The fill plug is in the mid section of the transaxle. The drain plug is near the bottom of the transaxle.
The oil level is checked by removing the oil fill plug on the side of the transaxle. The transaxle fluid should just meet the lower threads of the transaxle fill hole.
Remove the oil level check bolt from the side of the transaxle. If oil runs out, or if oil can be felt near the threaded fill hole opening, reinstall and retighten the bolt to 33 ft. lbs. (45 Nm).
If the level needs to be topped off, pour oil in slowly until it begins to run out then, install and tighten the filler bolt to 33 ft. lbs. (45 Nm).
Cheers,
"Please rate this solution or kindly leave a Testimonial"
Use only genuine Honda manual transaxle fluid (MTF)-it is specially formulated for use in Honda transaxles. If Honda MTF is not available, API SG/SJ 10W-30 or 10W-40 motor oil may be used as a temporary lubricant. However, motor oil will cause increased transaxle wear and shifting effort. Refill the transaxle with Honda MTF as soon as possible.
Manual transmissions use gear oil, not automatic transmission fluid.
There will be a filler plug on the side of the gearbox. The gear oil should be filled up to the very bottom of the filler plug hole.
drain plug on the bottom of the gearbox,fill plug on the side of the gearbox and you only fill it till it just starts to run out and put plug back in should be 24 mm plug
Just to confirm that the oil Fill plug to a Daewoo lano manual tansaxle is on the right hand side of the transaxle where the drive-shaft exits the gearbox housing.
CHECKING FLUID LEVEL
1. With the vehicle on a level surface and the fluid in the transaxle cold, remove the filler plug and check the fluid level. The fluid should come to the bottom edge of the plug hole.
2. If the level is low, add SAE 80 manual transaxle fluid through the filler plug hole until the fluid begins to run out.
3. Reinstall the filler plug and tighten it securely. The speed gears and the synchronizer parts on this vehicle receive lubrication through specific passages in the mainshaft. It takes 1.8 liters (1.90 quarts) to fill the transaxle completely.
its located next to drive shaft some on left hand side others on right hand side depending what gearbox.
You can actually do it from the top if it is similar to a 2001 Elantra??? On your right center of the tranny, there should be two big bolts I believe a 17mm one on the bottom left the other top right of the other. The bottom left is the drain plug the top right is where you fill it. If you want to make things easier you can remove the air cleaner and the air cleaner housing then unscrew the sensor on top of the tranny you can poor it in from the top. You will need to then unscrew the fill hole (Top right bolt) Pour the lube in to the hole where you had taken out the sensor until it pours out of the fill hole. Sounds like more work but by doing this you will avoid making a mess trying to fit the squeeze bottle into the tiny hole. Hope this makes Sense????
same problem, I need a photo to show me where the filler plug is located
