Question about Hotpoint TS13 Electric Portable Dryer
TS 12 Reversible electric dryer
The tension wheels of the drive belt contact the dryer drum during rotation causing a banging sound. How can the dryer body be dismantled to get at the tension wheels without causing damage to the appliance structure?
Easy !! remove the front door section complete ..
remove timerknob. + screw unclip the whole panel plastic.
remove 4 screws just under the plastic panel and then 4 screws on the bottom or front pannel. leave the screws at either side ON. you can then change belt/motor/pulleys. hope this helps.
Posted on Nov 25, 2008
  • 291 Answers
Cant bring up anything with that model # should be more to it
Posted on Sep 05, 2007
Asko dryer make a banging noise
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Oct 02, 2014 | Asko Dryers
Why does My dryer make a noise when it starts and stops? It also makes some sounds when it is running
how long have you been using the dryer? seems to me you might have issue with the razor or the drive belt. you might want to get a professional to have a look at it.
May 27, 2014 | Daewoo DWR-WE5413 7.3 Cu. Ft Capacity...
Hoover condenser dryer, drum is stiking, if i manually spin the drum ir will go bk in cycle
see this causes and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear. Check our videos for other style dryers.
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace the Belt along with the idler pulley.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing housing if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play. This video walks thru another type.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower wheel. Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor.
Oct 02, 2012 | Dryers
After replacing my belt and drum rollers my roper dryer has a clicking noise as it rotates
Could be a lot of things causing it, blower wheel, motor, idler pulley, rollers. Dryers have several moving parts that could cause a clicking sound. The blower fan could be coming into contact with something. There is a motor, tensioner and a belt that turn the main drum, the tensioner for the belt could be loose thus causing the clicking noise as well.
Oct 16, 2010 | Roper REX3614KW Electric Dryer
Belt in place, motor turning, belt moving very slow or not at all. slipping?
This is usually caused from a worn belt or a faulty belt tensioner. From the back of the dryer you should be able to see the belt tensioner and see if the wheel on the tensioner is turning. If it's not then you need a new tensioner, if it is then its likely to be a belt.
The other causes for this problem may be a drum wheel or drum bearing which has failed. The drum wheel hold the drum up and are located generally on the bottom of the drum. These wheels have a brass center for a bearing and if they are bad will generally cause a grinding or squealing noise.
Aug 04, 2010 | Maytag PYE2300AY Electric Dryer
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I'm having a problem re-fitting the drive belt to my Simpson Sirocco 455 tumble dryer. After installing the belt around the drum, drive pulley and tension wheel, I align the front end of the drum with the...
After some mild swearing, I made sure that I had the belt around the drum aligned (in the same plane) as closely as I could with the drive pulley and tensioning wheel. I think this was partially achieved by placing the belt as close to that position as possible before lining up the front end of the drum with the cabinet opening, and then turning the drum from the front (through the open door) very slowly clockwise (the direction of its normal rotation) to give the belt "time" to align itself fully with the smaller pulleys. A short prayer and a few minutes later, the machine was humming away with all parts playing their "part" in beautiful harmony - without the dreaded sound of a thin black drive belt cluncking to the floor of the metal cabinet.
Andy B.
May 02, 2009 | Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Hotpoint TS13 Electric Portable Dryer Logo
96 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
