It sounds like you are having some issues with your FoodSaver vacuum sealer. Here are a few things you can try to troubleshoot the problem:
Make sure that the FoodSaver is plugged in and turned on.
Check the sealing strip on the vacuum sealer to make sure it is clean and free of debris. A dirty or damaged sealing strip can prevent the vacuum sealer from working properly.
Check the vacuum bag to make sure it is properly positioned in the vacuum sealer. The bag should be inserted with the open end facing the sealing strip.
Make sure that the bag is not too full. Overfilling the bag can prevent the vacuum sealer from working properly.
If the problem persists, you may need to take the FoodSaver to a repair center for further diagnosis and repair.
I've found with mine I have to hold down firmly on the top while unit is heating the bag to seal it. I continue to hold the lid down for about 10 seconds after heating stops until the seal cools. Hope this helps.
Possible the water pump has gone out. I changed mine out it was not too hard.Also make sure the pump lines are all still attached and not clogged.This will take a little dis-assembly.
There is a heating element in your unit that seals the bags. Most of the units you cannot replace the heating element. The company is pretty good about warrantying the units. They go by the number on the plug to tell if the unit is still in warranty. Give them a call. 877-777-8042
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
