Question about Toshiba Satellite A105-S4074 Notebook
Won't come on
There is only a little amber colored lite flashing in the front of the lap top it was on and all of a sudden not
    Sergeant:
  • 457 Answers
The problem lies in the adapter on the power cord it may not be charging your battery anymore try and get another adapter? plug it in and see if all the lights light up again that would be the problem all fixed.
Posted on Sep 06, 2007
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
http://www.youtube.com/watch?v=oDGjWOabJ2E&feature=related
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1&feature=fvwp
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
This is my second dockstar, and both have just gone to rapid blinking amber lites. seagate doesn't really tell you any thing.
moz-screenshot.pngmoz-screenshot-1.png1-If you never shut off the device try to turn off for 4 hours and try to use it again.
2-The bottom light must flash when is on,if not you have a power supply or net cable problem.
3-If the top light is amber is indicate you have a disk problem
4-Do a power cycle
5-if the problem continues run the disk diagnosis utility from the web interface
6-If fails the drive needs replacement, check for warranty
7-Try to do a system reset.Press and hold the switch( a small hole at the bottom of the Ethernet) until the top front light flash and allow the unit to restart.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 01, 2010 | Seagate FreeAgent DockStar Network Adapter...
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
ERROR LITE FLASHING
this error indicates 1 of the following.
the front cover is open
the back cover is open
paper jam
usually its the back cover, either its not fully closed or the swing gate inside is not in track with the sensor, it has to be pulled out realigned and put back in.)
also possible there is a little piece of paper jammed inside the front or back area.
thanks adi
Aug 19, 2009 | Brother HL 2140 Laser Printer
Lap top is beeping, and then shutting off in the booting up sequence, then battery lite is amber
Defective battery, sounds like it won't hold a charge. Try it without any battery installed, see if it boots on AC power. If it does, I'd suggest a new battery. If not, then there might be a problem with the charging/power circuit on the motherboard itself.
Good luck, and please rate this solution if you feel it has helped!!
May 11, 2009 | Toshiba Satellite P105-S6104 Notebook
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
Won't boot up
Can you give a little more information? Did the Laptop Fall? What Color is the light that blinks? Amber or Green?
So far it Sounds to me that you Power Supply is Dead or Bad and or not charging the Battery....
First Check the battery status light?
Is the Power Supply Light (Lite). you might want to try removing the battery and using only the Power supply!
Jan 15, 2008 | Dell Inspiron 4150 Notebook
Toshiba Satellite A105-S4074 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
