Question about Microsoft Digit Media Pro bx100005 Keyboard
Installation of MS Dig Media Pro Keyboard
When trying toinstall to my Acer Laptop Travelmate 5623 running XP Pro I get an error message saying the hard drive may be full or another unexpected error has occurred
2 Suggested Answers
  • 102 Answers
SOURCE: Compatible?
As long as you can plug it into the laptop, it should recognize the keyboard straight away. With a laptop in mind make sure you get the usb version of the keyboard (that is if your laptop is modern enough to have usb ports).
Posted on Aug 16, 2007
  • 42 Answers
SOURCE: Wireless Laser Desktop 5000 and Mouse installation
Hi i would y going to the web site and check with them if you have thee right drivers for your XP OS as some programs still do not ship with the right drivers if this fails try just disconecting your mouse and key oard the shut your PC down and start it up again when you hear the beep to let you know that you do not have a key baoard or mouse reconect the two items may be XP will try to load you key board and mouse for you as it has a host of drivers for most components Hope this works Paddy
Posted on Sep 23, 2007
0 characters
1 Points
I need network drivers for travelmate 660
To download network (LAN) drivers for your laptop click here
For other drivers for your laptop click here
Apr 04, 2011 | Acer TravelMate 650, 660, 800, 6000, 8000,...
I have fractions on my keyboard, how do i get them on my screen?
It's either a Shift+ the key with the character you want to print or an FN(The Fn Key)+ the key that has the character you want to print. This assumes your drivers for that keyboard are actually loaded in the OS you are using and the OS recognizes the special keys. These are not normal keys.
Oct 29, 2010 | Acer NSK8458AN Keyboard
I have installed a new external keyboard (Kensington) for use with my Acer Travelmate 4670 laptop, using the XP auto drivers. However since this instilation the laptop keyboard settings have changed, the K...
There is a possibity in the system to change keyboard-type (not language): Start/Configuration/Keyboard - choose the right type. I think that the system still things the external keyboard is atached whils you're uising the built-in one - which seems to have different keycodes, causing this problem
Aug 11, 2010 | Acer NSK8458AN Keyboard
I've got the same problem!
Download the drivers from the Acer WEB site Make sure you select the model of your laptop and the XP or Vista version of the drivers you require that matches the Windows version that is installed on your laptop. Use this link to get to the Acer support :-
Sep 19, 2009 | Acer TravelMate 650, 660, 800, 6000, 8000,...
Keyboard Acer Travelmate 6291
sounds like the keyboard might have gotten wet. try to replace the driver then you will have to replace the keyboard they are practly un repairable.
Jun 29, 2009 | Acer NSK8458AN Keyboard
No operating system - instal xp pro
With what you have done, it seems pretty cut and dry. You hard drive appears to be damaged, which is why your having problems formating/accessing it.
I would recommend running a hard drive test. If you not sure how, I would ask a local repair shop to run a quick test on the hard drive to confirm its bad. Most shop will do this test for free, if you get a hard drive through them. If you wanna go online and get your own hard drive, testing should be less than 30 bucks.
If this helps please rate my solution.
May 10, 2009 | Acer TravelMate 650, 660, 800, 6000, 8000,...
Attaching to multi media projector issue.
A Function Key cpmbination is driving display choice: on my Acer (travelmate) is FN + F5 on your model could be different (On Compaq 6710 is FN+F4)
Check your manual or your keyboard for function symbol (Blue marked).
Allow time to perform a switch
Jan 04, 2009 | Acer NSK8458AN Keyboard
Acer aspire 7100 continually beeps while starting up
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
Nov 07, 2008 | Acer NSK8458AN Keyboard
Acer Travelmate 7510 series keyboard removal
see it this applies to your model
Nov 22, 2007 | Acer NSK8458AN Keyboard
How do I replace laptop keyboard ?
Praf, You?re in luck, its fairly easy and Acer has detailed instructions with pictures no less. Here is the link: Let us know if you have any other questions and please don?t forget to rate this post.
Apr 24, 2007 | Acer 91.63X07.001 Keyboard
Microsoft Digit Media Pro bx100005 Keyboard Logo
18 people viewed this question
Top Microsoft Keyboards & Mice Experts
micky dee
Are you a Microsoft Keyboard and Mice Expert? Answer questions, earn points and help others
