SOURCE: dell 5100cn code 009-363
Nicholas -
There is no real solution to this problem that I've been able to find. And I myself have not been able to find anyone that has the service manual for this color printer.
Here is what happened with my printer. I normally use this one company for compatible toner cartridges for our office printers. I've never had any issues with their HP, Brother, Canon Phaser or Dell laser products - EVER. When I went to re-order my Dell 5100cn toners again from them - ordered 2 black and 1 each cyan, magenta and color - none of the toners worked right. When they were installed, the machine produced that 009-363 restart printer message.
Now this company has ALWAYS taken care of me. We thought maybe the chips in the toners were outdated or something compared the the recent firmware update my printer had recently had. So they shipped out a complete new order for me. But the second set of toners did the same thing. So they sent one of their Dell Certified technicians to the office - we are on a cleaning plan with them so he just looked at the Dell printer while he was there doing the other work. He could not find anything physically wrong with the first or second set of toners, but yet they would not work in my printer. He even tried going through the menu options to select "allow non-Dell toners" too - thinking that maybe the printer just wasn't liking the Dell compatibles. I never had to do this before with their Dell compatibles, but it was worth a try. But even when selecting that, the printer still produced the 009-363 restart printer message. He took the toners back with him, and left me with a set of Genuine Dell toners - just to get me through what was happening so I wasn't down a printer.
The company called me and said when the technician returned with the compatible Dell toners they'd shipped me, they installed them in their test Dell 5100cn printer and they worked fine! So it was appearing that the problem might have been my machine or something.
I searched online everywhere, and the supply company I used also spoke with Dell tech support on my behalf - but got no where with Dell as usual - their Tech Support is totally useless!
About a month goes by, and my supply company says that they received a new shipment of Dell chips that have a newer firmware than even what my printer has, and that they'd like to send their technician out again to test them out in our machine. The tech came by, installed all of the toners - and they worked!
So it definitely was something to do with the firmware that was on my printer versus the firmware that was on the chips in their toners. My printer for some reason did not like that "lot" of toners they had made using those chips. And when they produced their next lot with the new firmware chips, the printer accepted everything ok.
Since then I've used their Dell compatibles with no issues. I think it was just a fluky thing as it hasn't happened since. Overall I think you just need to find a company like mine that continuously produces new toner cartridges using new Dell chips in their toners. Once in a while you might get a fluky one like we did, but my company definitely took care of us. Just try to find a company that has a good cartridge - you don't have to keep buying the expensive Dell brand - especially when they don't even know what the problem is caused by either.
SOURCE: 010 397 Error Message on Dell 5100cn
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
SOURCE: Dell 5100cn Paper Tray Won't Feed
i think you need to look your pc maybe something wrong inside your pc..try to do something for your dell..
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
SOURCE: Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
