Question about Marantz SR4600
Marantx SR4600 Receiver
I began having problems with my receiver about a month ago. I would power it on and it would stay on for approximately 30 minutes and would go off. The length of time tha it will stay on has gradually reduced to the point that it goes off immeditely after you power it on. When you power it on "Main Vol." flashes accross the display. The unit is approximately 6 months old.
    Master:
    Sergeant:
  • 461 Answers
Some indication of power supply issue. if it is 6 months old. It should be still under warranty. Should it not?
Posted on Sep 07, 2007
SOURCE:
Akai lct3285ta will not stay on for more than 30 seconds until it has been turned on more than 20 times. I've tried unplugging it for over a minute. Have owned tv for more than 5 years, and this only...
This problems u have 90% it is the tv Tuner signal board,that the board,where the imcomming broadcasting signal cables plug into it.This problems also 10% could be power supply board have dying capacitors parts.That the board,where the power a/c cord plug into it.Check all over the power supply board for capacitors are bulging ups on tops or puffing up on it tops.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards the tv Tuner signal board or the power supply board for the replacement.
Feb 02, 2011 | Akai LCT3285TA 32 in. LCD Television
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
Oct 28, 2010 | Thermador Freezer FREEDOM® T24ID80PLS
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Whirlpool Dishwasher cleaning light stays on
Try unplugging the machine from power to reset the program, if that fails you may need the control panel replaced.
Apr 19, 2017 | Whirlpool Dishwashers
My Denon AVR-788 receiver switches off by itself after it has
If you've changed it's location or added speakers, or placed anything on top of it since the problem started then consider that it may just be over heating.
Dec 19, 2009 | Audio Players & Recorders
I have had my tiburon less than a year but about a month ago the transmission started to act weird. At first it began shifting between i think third and fourth gear which made the rpms go higher than they...
the trans computer has seen a problem possible a bad sensor, or an internal problem, and puts it into a safe mode, or limp home mode , it wont shift , it will stay in 3rd gear, this way this reduces the possibility of further damage trans damage, when you turn the ignition off and back on it resets the tcm, my advice is to take it to your local dealer, they can diag your trans as they know the product, i dont advise pep boys, or discount auto parts.
Nov 18, 2009 | 2001 Hyundai Tiburon
My TV began with a flash of white light then will turn itself off. It won't turn off every time the screen flashes. It started a month ago then worked trouble free until now and it began again. You can...
I hope you have a service plan for this set. Most likely--the CRT"s are going bad. This was a VERY common problem for Sony sets of this age. the CRT tubes SHOULD last a long time...BUT Sony had a BUNCH of the tubes that had 'contamination" on the cathodes of the guns...and after a few years..this 'flakes off" and shorts out the tubes. There WAS a recall on these a couple of years ago, but I am not sure about it now. You will need ALL 3 tubes to fix this problem. If it was me...I would try and find out if there is any way to get Sony to cover it..., if the set is not more than about 8years old.
Oct 12, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a starmate2 replay and what has happened is i turn it on and it stay on the title screen thats it.None of the buttons will work on it only the power button to shut it off.Please help
Three months ago I had the same problem. My wife paid over $300 for the radio, the portable boom-box and subscription less than 2 years ago.
Sirius offered no help or discount on a new radio. Guess they follow the Microsoft doctrine because they suggested I upgrade to a new radio.
Anyhow, feeling frustrated, I took the receiver apart, thinking that a stray voltage on an IC ping maybe causing the problem. It was only a guess. I don't even have a wiring diagram At any rate, once I had it apart, I used a small flathead screw driver and drug it (lightly) across all IC pins, possibly in an effort to drain the voltage. Please do this in a low static area.
When I put everything back together, the receiver worked. It's been working good the up until about 2 weeks ago, when the same problem began again. I just finished the same process and the receiver is working again.
I don't advocate this for anyone who doesn't know how to handle electronics.
I'm just very disappointed in Sirius for not admitting the problem and providing no discount for a newer model. I have a $10 clock radio that's 9 years old. Guess what, I don't have to take it apart every three months to keep it working.
Ken in PA
Jul 20, 2008 | Sirius Starmate ST2 Satellite Radio...
Screen black out
this is a upper buffer board problem, the board is not to expensive but the if you are not a repairman, I would not attempt it
Jan 18, 2008 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Marantz SR4600 Logo
204 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
