Cars & Trucks Logo
Anonymous Posted on Aug 15, 2013
No power to fuel pump on an 2002 Holden Astra
Richard Gorenflo
Level 2:
Champion:
  • Expert 210 Answers
  • Posted on Aug 15, 2013
Richard Gorenflo
Expert
Level 2:
Champion:
Answers
210
Questions
13
Helped
53063
Points
493
Has vehicle been in a minor accident or made a sudden stop. It may need the inertia switch reset or may not have enough oil in the engine which could also stop the fuel pump from working.
Testimonial: "No accident, my wife said the motor just died on her and would not start. I checked and there is no power to the fuel pump."
5 Related Answers
Anonymous
  • 1990 Answers
  • Posted on Jan 22, 2009
SOURCE: changing a fuel pump on a 1991 holden barina
The Fuel Pump is Inside the Fuel Tank. You will need to Trop the Fuel tank for this. Not an Easy Job by any Means.
Anonymous
  • 662 Answers
  • Posted on Aug 28, 2010
SOURCE: 1989 holden astra slx 1.8l
The ecm light comes on for a reason, and it is hard to work out the problem, until you find out what codes the computer is registering....i would suggest that you take vehicle to a local mechanic and get him to read the codes....that would give you and us an easier way to find out whats happening.......
Anonymous
  • 65 Answers
  • Posted on Nov 19, 2010
SOURCE: My wife has a holden
you will have to puchase a window handle removal tool from your local parts store. KD makes a good one but you wiil have to use this tool to remove a clip that holds the "winder " on.
Testimonial: "Thanks verry much I would have broken it if I had kept going."
ME
  • 14 Answers
  • Posted on Dec 08, 2010
SOURCE: POWER WINDOWS NOT OPENING OF HOLDEN ASTRA CD TS
Hi I had the same problem and replaced the winder mechanism for $74. I wrote a complete 'do it yourself' How To with pictures at this link:
http://www.opelaus.com/forums/showthread.php?27769-AStra-Window-regulator-repair-replacement&p=635716#post635716
Scroll down for the full article.
Anonymous
  • 504 Answers
  • Posted on Apr 24, 2011
SOURCE: 2002 Holden Jackaroo 3 Ltr turbo diesel... Fuel
TRY SCRAP YARD FOR SECOND HAND UNIT
Hi had a fuel pump replaced a week ago. Filled up tank to full. Have driven half a tank (350km) fuel gauge shows near full. How can I reset the gauge?
I would get the pump and sender unit installed properly. Sounds like the float is stuck due to an incorrect installation.
2002 holden astra fuel pump relay and fuse locations. car also known as a vauxhall 1.8 litre motor
The service and repair manual with diagram and pictures will provide you step by step help to locate and fix the problem easily and you will get the manual from the given link https://toolsnyou.com
Location of 2002 holden astra fuel pump relay and fuse i think they are also known as a vauxhall
Google it make model year and they have the
Schematics free for downloading. Goodluck
Where is fuel pump 2002 holden Astra
Hi Geoff The fuel pump is inside the fuel tank. I think there is an access panel (circular) under the rear seat. If you are thinking of changing the pump make sure you don't have a full tank and make sure battery is disconnected. Also on completion have your radio code as you may need it when battery is reconnected. You haven't mentioned why you require this information, be aware there is a fuse and probably a pump relay in the circuit. If they are ok and you can't hear the pump priming try thumping the center of the tank with your fist (do not use anything else) whilst turning the key on if it starts priming you have a pump issue. If you do replace the pump its worth while cleaning out the tank to make sure there is no foreign matter inside. Also fit new o ring seal and clean sealing surfaces. Good luck
Where is the fuel pump relay on a 2004 holden astra ts ?
its inside the fuel tank, there is a accsess above the pump the fuel gauge is also fitted to the pump. panel in the boot.
I need to know where my fuel filter is located Holden Astra 2001
Hi Tracy I believe your astra is a TS version filter will be attached to fuel pump in fuel tank. Hope this info helps
Where is the fuel pump located in a Holden astra 2003
It has lines comming out of the tank to the injectors not where you put the fuel in but close to the bottom near a corner or on a low side of the tank thatll be the fuel pump
2answers
Holden astra 2002 rough idol
If you replaced the timing belt and the car has been doing this, it is possible you are 1 tooth out with the timing belt.
3answers
Where is the fuel pump relay located on a 2001 holden astra 1.8
The fuel pump relay is located under the hood near the battery.
Usually in a black plastic box. There will be some fuses and other relays in as well. It should be marked fuel pump on or under the lid.
Good luck. Replace with same relay.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
