PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Laptop won't boot
By icebreaker on Sep 05, 2007
Lap only boots to startup config screen (safe mode/last known good etc. won't go to any of these - just keeps rebooting.) Tried the xp floppy boot disc (on ext. drive) & GET THE SAME RESULT.
Don't know how to get to recovery screen (if it has one !)tried F10/11 However,it will go to BIOS screen. I don't have the original disc to reformat the drive & I can't see any support button on the Evesham site to get one.
Can you advise,
Many Thanks,
icebreaker
Comments:
Sep 05, 2007
- Thanks could you send the startup disc for me please. If I insert the disk in external floppy what will it do, will it go to a startup screen or something.
Cheers,
icebreaker
Sep 05, 2007
- Thanks again, would you know what causes this problem
Sep 06, 2007
- Thanks, I managed to get the recovery console going, did fixboot & the boot sector was corrupt. the rec.said it it repaired the boot sector.I restarted it & the pc was back to square one.
What can I deduce from this (is the hard drive beyon repair ?)
Sep 06, 2007
- Sorry, I don't have the original XP home disk to \i386 it, just XP PRO off my other pc's.
Sep 07, 2007
- Thanks, the problem still exists even though I used FIX/MBR (after FIXBOOT)as well.I used a windows 98 boot disk to get it going,then I used 6 XP HOME boot disks to get into recovery console.Console comes up with the options Just as the C: prompt and not C:\WINDOWS. However I tried various actions as a test and they seemed to work.
If I reformatted the drive (if it allows me to !) can I install O/S from WINDOWS XP PRO. disc I already have off my other pc & would I do this as a normal installation of off \i386.
If it's off \i386 folder, how would I pull it off the disc.
Cheers,
Freddie
Sep 07, 2007
- Thanks, I have an XP PRO cd with serial.How do I create an install disc.step by step instructions please.
Sep 07, 2007
- This is now fixed and XP is up and running again without an OS reinstall.
Many Thanks for all your help.
Same Problem
Dec 28, 2008
-   my netbook only turns on and gets as far as d load page and then it says it could not find the a bootable device...and tells me to insert a bootable device and press any key!??
it also clicks a bit when i turn it on...is this normal??? please help me,i bought it as a christmas present for my girlfriend and its not workin :(
-   altimeter
Dec 26, 2008
-   can some 1 help my acer travel mate at start up goes 2 a black screen saying windows could not start cos the following file is missing or corrupt
<windows root>system32hal.dll.
please reinstall a copy of the above file
problem is i dont evenhve a copy and when i f8 it doesnt give me the safe mode options either please help i have 2 use a crappy elonex that i got and thats a pile of poo
-   gillwatt26
Dec 13, 2008
-   IBM R51 NO DISPLAY ,, ONLY BEEP,, NO BOOT -   ITGUWAHATI
Dec 10, 2008
-   It just won't boot. Similar to the other problem. It just goes.. F2 for set-up, F12 for LAN. But if I just let it run, it shows Windows. And it's not even loading ! It just shows the logo.. And nothing happens. And it shows safe mode, blahh, blah after I enter setup. But nothing helps.. Please, I'm in desperate need of help !
-   Guest
Dec 01, 2008
-   I cant get the laptop to boot from the cd, Can you help -   Guest
Best Solution
posted on Sep 05, 2007
Helpful)
24 seven
Rank: Wiz
Rating: 82%, 1405 votes
try using a WINDOWS ME edition startup floppy disc. I had good results with this version. I can send if you want. This will allow disc access to investigate the problem. You will still have XP on disc.
Comments:
Sep 06, 2007
- well, you tried the xp floppy disc...same method...you will get a choice screen to select boot only or boot with cd-rom drivers. first boot with out cdrom then run scandisk (off floppy) on c drive to correct errors. then attempt to read c drive and somehow backup all important data because you will lose everything on hard drive after next events to follow. then reboot and run format c then reboot with cdrom drivers and begin installing xp all over. remember, you will lose everything on hard drive. hope you have xp cdrom, also. ready? then reply with email to get floppy files.
Sep 07, 2007
- by saying "back to square one", do you mean the problem is still bad or do you mean problem is gone?
I don't believe you need the xp home, except if special cd with oem drivers for this manufacturer laptop. if you feel you can get all drivers, then any xp install disc should work.
remember to run scandisk if you ever get drive to be recognized again by system. the hd may not be dead yet.
Sep 07, 2007
- please clarify: "...XP PRO. disc I already have off my other pc"...do you have the cd or not?
although it may be possible to install xp via a wired (or wireless) pc-pc connection, I do not recommend it at this point. you should create the cd from the other pc's xp install files (assuming you actually have copied the xp cd onto the other pc hd). about re-formatting drive, be aware that if you want NTFS instaed of FAT32, you must reformat using XP (or 2000) startup disc.
Was this helpful?
Yes
No
Solution #2
posted on Dec 28, 2008
Not Rated)
cod01
Rank: Apprentice
Rating: 0%, 0 votes
my fujitsu latop is stuck in configuration step 3
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how loose the keyboard, some of the keys stick!!
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
I have a Compaq v 5000 and the screen colors are the opossite of what they should be, is it the LCD,... (More)
Answer
i have a gateway solo 2500 with trying to use a samsung 40gb harddrive cdrom reads up but wont... (More)
7 Other Users Have The Same Problem - Continued
Comment by Shananjoe, posted on Oct 11, 2008
My dad just bought a used Toshiba Satellite A70: A70 Intel Pentium 4 processor 3.06GHz, 512MB RAM, 80GB hard drive, DVD-RW multi... PC Notebook. This laptop came without a O/S. We did receive the System Restore DVD but we are having problems. When we try to install the recovery it will only run for about 5 minutes and the laptop shuts down. We restart and it says it is continueing to install windows. Please give me exact directions so that I know I am doing this correctly. We have a copy of Windows 98 with the key code. What am I doing wrong? Please help.
Shana
Comment by Guest, posted on Dec 22, 2007
acer travelmate series 2310 says we apologize for the inconvenience, but windows did not start successfully. a recent hardware or software change might have caused this.
if your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose last known good configuration to revert to most recent settings that worked.
if a previous startup attempt was interrupted due to a power failure or because the power or reset button was pressed, or if you aren't sure what caused the problem, choose start windows normally.
safe mode
safe mode with networking
safe mode with command prompt
last known good configuration(your most recent settings that worked)
I tried all of these options and it won't boot
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
