Guest
Rank: Apprentice
Rating: 0%, 0 votes
The F2 fault where it drain pump starts the second the dishwasher is turned on comes from a switch that is connected to a piece of styrofoam that is just behind the place you make the electrical connections, and just below the area where the circulation and drain pump are. You can feel it if you FIRST TURN OFF THE POWER, and from the inlet side run your hand on the top of the pan to below the middle section. Push the styrofoam down. If it's wet, wait for it to be dry -- Sometimes it's caused by stuff that sneeks under the styrofoam and makes the dishwasher think it's water. A vacuum can help (if there really really is no water...)
