Question about Hyundai Electronics E320D 32 in. LCD Television
F-scart conectio to a open box (satelite)
When i try to conect a f-scart to lcd, it can find the signal to satelite or what so ever, why is that? no problems when i conect to other tv. Maybe the f-scart is corrupted? the LCD is bran new
  • 1 more comment
  • lisij Sep 05, 2007
    on tv? or on the remote? if remote than there is an source option, im puting it on the f-scart, and still no signal
    already try this one, any other ideas?
    yes it was, and seems have no problem, but when i'm conecting to lcd, writes on screen No Signal, and i can't enter the satelite settings, cause it not despaing nothing on lcd
  • 2,961 Answers
There may be input settings on the tv that need to be changed, there should be an option to change inputs from HDMI to DVI, or scart
Posted on Sep 05, 2007
  • andrew pester
    andrew pester Sep 05, 2007
    normally on both in the menu on the tv or source or input on remote, if you have two scart sockets the output setting on the tv may be set to the wrong one, so swap over the socket if you can.
  • andrew pester
    Was the other tv connected by scart?, if not you will have to go into the sattelite settings and change the output in that to scart.
    after that im at a loss, try another lead.
If it comes on at exact same time it could be programmed to do that and a few set top boxes are also capable of that--set detects active signal via rear inputs and comes on.
Apr 08, 2012 | Televison & Video
How do i connect a sky+ hd box to dvdr and vhs recorder? want to free up some space on the Sky+ box. i have an LG tv and the sky box is the only equipment with only 1 scart. all others have 2 each
The sky+ box only has a scart out, not in, so this has to be the first in the chain from the aerial / satelite dish.
You can get a scart lead with two plugs at one end and one at the other but you would do better to get a multi-way scart switching box that will let you connect all your scart based equipment together. Make sure that all your scart leads are the sort with all 21 pins connected.
Feb 18, 2011 | Philips Televison & Video
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
Used to be hooked to satelite ,now cable and says
Unplug,replug the cable box about an hour later,let it reset itself.The box will reboot itself,and upgrade the software.the signal should work again,not the cable box is dead must replaced.
Apr 26, 2010 | RCA L32WD22 32 in. LCD HDTV
I have a Grundig VCR which will not record tv programmes although it will play tapes quite normally. the skart lead is connected and i have tried changing it around and even a different one. cannot see...
You need to input a signal into the video from either your aerial or cable box etc. these are connected by either a scart from the cable/satelite box or the aerial input in the rear of the VCR, you will then need to tune the VCR in if using the aerial.You will not be able to record anything if there is no signal.
Apr 14, 2010 | Televison & Video
Connecting a standard cable box to an HDTV and remote doesn't run cable box. After I connect my new HDTV to my standard(non HD) cable box if I use my remote to do a channel up or down it just starts...
are you connecting by scart ? if so some hdtvs send signal backfeed/try aerial tv out to tv/also try basic scart lead as scarts can be faulty dont fit a pound shop one get a top one from maplins etc
Nov 10, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Connect jvc combo vhs/dvd recorder to satelite and tv
If your satellite box has two sart outputs. Scart1 should go to the Tv Scart 2 to the input on the Video. Then the output scart socket on the VCr should go to Scart 2 on the TV
Sep 23, 2008 | Televison & Video
I bought dvd hdd recorder 3 days ago from lidl it is a targa DRH-5700X seriel no. e5809000859. Imust not have it connected right as i cannot get anything from it on the television.Ihave the recorder...
i have a targa 5500x from lidl cant copy from hard drive to dvd as i have done this many times but the dvd drawer keeps opening telling me to put in blank dvd and i keep doing this but getting no where,
Apr 23, 2008 | Toshiba SD-4000
Hyundai Electronics E320D 32 in. LCD Television Logo
149 people viewed this question
Top Hyundai Electronics Televison & Video Experts
Tom Chichester
Are you a Hyundai Electronics Televison and Video Expert? Answer questions, earn points and help others
