I bought a Sharp 13" TV (mod. 13K-M100) to put in my bathroom. Right outta the box it trips the GFCI on power up - but only when cable tv coax is attached. There is another tv fed by same GFCI - a 31" monster, but GFCI never had tripping problem until the 13" came along. And unplugging the 31" set doesn't stop the 13" from tripping the GFCI. I bought a second identical 13" tv at same time and it trips the GFCI too. I have tested the GFCI with 22K and 33K resistors to see if it's within specs, and it appears to be - the 22K trips it, and the 33K doesn't. What is going on here?
I hate to oversimplify things... but how about plugging the TV into a different circuit that doesn't have a GFCI on it? If this TV is going into a bathroom (WHY does anybody need a TV in the BATHROOM???) mount the TV high on the wall and keep the non-GFCI protected receptacle at lease 6 feet away from any plumbing fixture. Use a single (not duplex) receptacle dedicated for ONLY the TV. (And only operate the TV with a batter-powered remote control!)
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
herself - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Four days later: I replaced the GFI and now everything works OK. Thanks for all the advice, everybody. Jim
Was this helpful?
Yes
No
Solution #3
2Pansy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Bob Weiss <bwe @carroll.com> wrote:
Or completely isolate the antenna circuit with a transformer pair? I don't think a pair of back-back baluns will work though... you'll need a true RF isolation transformer on the cable/antenna lead in.
-- ------------------------------------------------------------------------- | Had your share of stoopid(tm) people? | | | View the "Contra Costa Whines" at | [This space for lease] | | http://www.io.com/~tweek/cocow hine/ | |
Was this helpful?
Yes
No
Solution #4
jessie25 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Chances are that the TV has a 2-wire polarized cord, with no direct ground connection. When you connect the CATV cable, you connect an earth ground to the system via the shield of the coax. The antenna connector of the set is actually connected to the neutral side of the powerline (probably through a small capacitor). This capacitor has a low enough reactance to pass an AC current from the powerline to ground through the coax. This is exactly what a GFCI is supposed to detect, and it responds by tripping out. By connecting the grounded coax, you are effectively grounding the neutral side of the line. This is supposed to be done, but ONLY at the service entrance panel! You have created a ground loop, and the current caused by the potential difference between the neutral at that GFCI, and the coax shield (which should be grounded only where it enters the house) is causing a problem. The only quick fix that comes to mind is running the set on an isolation transformer (carefully grounding one side of the secondary, as it is now the neutral in a "separately derived system"). Other options include running a dedicated line from the entrance panel to feed the set (not a sure fix), or eliminating the GFCI (definitely NOT recommended).
73, Bob Weiss
Was this helpful?
Yes
No
Solution #5
maartenw - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
In the coax (one in series with the screen and one in series with the inner core, mount 2 2nF capacitors (or the like). Put a plastic box around it.
hi--can anyone please just tell me where one attaches the antenna on the Sharp 13K-M100?
thank...
(More)
thank you!
Can I get a list of codes to enter in to my remote, so the Time Warner Cable remote will control the...
(More)
Can I get a list of codes to enter in to my remote, so the Time Warner Cable remote will control the tv?
Hi. My time warner remote won't operate my Sharp 13K-M100 television? Any help would be much appreciated.... michelle :)
