Question about HSM 125.2hs Shredder
Hsm 125 whilst shredding, i could smell a burning smell. Since then, although the machine will run backwards, it will not shred. i have not oiled the machine since purchase about three years ago
  • 30 Answers
Sounds to me like a the main control board is fried. That smell was probably a resistor or a rectifier burning. The fact that you hadn't oiled the shredder in 3 years didn't help, probably put an extreme load on the drive motor. You might be better off, shopping for a new shredder, unless this is a high end industrial strength model.
Posted on Sep 05, 2007
How do i increase the number of pages that the shredder will shred at one time?
you can only shred what it will take , trying to force more in will only break it faster .
Oct 16, 2015 | Shredder Office Equipment & Supplies
Will not shred no matter what I try to do. I have run it backwards and forward and it still will not shred. Please advise and thank you.
If you want to keep it , I think you should dismantle it make a mental note of how you do it, free any paper jam and spray the cutter blades with a thin layer of WD 40 or similar then you should be good to go unless the motor is burned out from you constant on off testing
May 25, 2015 | Royal VF1700MX Shredder
Intimus 602 shredder not shredding
Does it run backwards? If it runes in the right direction, it should take paper. You only should use the reverse, when the machine got stuck. But perhaps it now is running back. Or something broke, so the motor is running, but not driving the mechanical parts inside.
Jul 27, 2014 | Intimus 602 CC Shredder
Spins and will not shred
Not real familiar with your particular shredder but most shredders have plastic gears that will break teeth so that you do not destroy the motor when a jam happens. My guess is that is what happened to yours. You can usually contact the manufacturer or a dealer to see if new gears are available. You will need your model and maybe your serial number when you call.
Aug 15, 2012 | HSM 225.2 Shredder
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
Machine won't shred. Does turn on, and goes in
You dont say make or model so...get some shredder oil into the cutting teeth where you insert the paper...especially if its a x-cut shredder..make sure once in a while you shred a piece of paper with some of the oil poured onto the paper for lubrication of the cutting blades.
Mar 04, 2010 | Office Equipment & Supplies
Turns on and shreds for about half a page, then automatically reverses.
My shredder is jamming. Would oiling it help. I have never did anything with it until now it needs help.
Nov 09, 2009 | HSM 125.2hs Shredder
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Apr 13, 2009 | HSM 225.2hs Shredder
Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
HSM 125.2hs Shredder Logo
229 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
