Question about Motorola Mobility RAZR V3
Screen Blanks, Phone Turns Off Sporadically
On the day of occurance, yesterday, I used my bluetooth ear piece and was using/re-charging my phone in my car. Later (out of the car) I noticed the screen went black but I was able to "blindly" dial a phone number on the keypad and the call went through. When my phone was called (from a land-line) the phone rang but I couldn't "answer" it. I was able to remove/re-install the battery, re-power and the display and all of the phone's visual functions were working properly. However, the bluetooth indicator kept flashing even though my earpiece was turned off. Then the screen blanked out again almost at the same time that the screen-saver would normally kick in. Some times I can flip open the phone and everything seems just fine, and then all of a sudden the cycle repeats. Another time after doing the battery drill I was able to call the phone from a land-line and the call would go through just fine. And then ...
  • Anonymous Feb 16, 2008
    dropped my phone in water and then screen went blank after it all drying
  • moke2000 May 11, 2010
    your instructions not very clear. what is this ota and def pass and when do i try a master reset, and does the phone have to be in some kind of mode or something?
  • 47 Answers
You can try to disable your bluetooth in your settings on your phone when you have a screen and ask your service provider to send a ota to your phone that will send your settings to phone and try a master reset on phone def pass for that is 6 zeros :000000
Posted on Feb 16, 2008
Looks like a battery problem. You might want to replace it.
Posted on Sep 08, 2007
What replacement charger do i get for my n136 bluetooth ear piece
The same kind you use to charge an android style cell phone. You can get a USB cable that has the correct end for the headphones and use your computer to charge it too.
Feb 21, 2016 | Radio Communications
Need to hard reset motorola mini bluetooth h9
try removing the pairing to your phone and pair again. If this does not work try pairing your headset to another phone and if it does it on that phone then something is wrong with the earpiece return for repairs if under warranty or if you are willing to pay for the repairs if out of warranty or replace ear piece all together as they are reasonably priced these days. If the ear piece works fine the other phone something has gone wrong with the bluetooth side of your phone return for repairs or replace depending on what you can afford to do. I hope this helps.
Aug 26, 2012 | Motorola Mobility H9 Mini Bluetooth...
Can you think of any reason my Plantronics 520 bluetuth device suddenly would refuse to connect with my Dare LG? Never had any problems linking the 2 together until now. When I power the device on it...
You may need to do a hard reset on your phone to re pair it back with your cell phone, let the battery go empty, remove put back in charge. Make sure that the headset is flashing red/ blue, this tells you that your headset is looking for a bluetooth application.
Plantronics Voyager 520 User's Guide
Good luck from Headsets Direct!
Mar 08, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
How to use the ear piece
hi there. you need to charge the bluetooth earpiece, then, when it is on, search for its bluetooth. if it doesnt show up, play some music, then go options and go on "play via bluetooth". and then search from there.
hope i helped!!!
Nov 12, 2009 | Samsung SGH-G600 Cellular Phone
Set up bluetooth devise
Go to the setting menu of your phone, select connectivity to choose bluetooth, Select Paired devices but make sure your ear piece device is power on, that is the bluetooth it on, search for it, then paired your phone with it. that is all.
Sep 21, 2009 | LG Vu CU920 Cellular Phone
Can't hear anything when I used my bluetooth ear piece
When connecting, you must be sure the phone is set to connect to the model of bluetooth earphone you are using, and the connection goes through, Once it makes the connection, it will stal connected until you disconnect it, again using the phone's disconnect key.
May 26, 2009 | Google Android
Short time between bluetooth charges
You should have up to 4 hrs talk time, and 180 hrs of standby.
Make sure you charge the 2050 until the l.e.d. turns off. As long as the light is on, its still charging.
If you did that, I would return the unit for exchange, your may have a defective battery.
Mar 17, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Can not turn ear piece on
JUST HOLD DOWN THE MIDDLE OF THE EAR PIECE FOR EIGHT SECONDS
Jul 02, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Plantronics ear piece
i need a passcode for my bluetooth so i can put it on my blackjack
Dec 06, 2007 | Plantronics Explorer 320 Headset
Motorola Mobility RAZR V3 Logo
81 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
