Question about Compaq Armada E500 Notebook
Computer wont start
When power is pluged in, both lights-battery light & power light, starts flashing but computer wont boot...even processor fan isnt working..plz help
  • 1 more comment
  • fnctyusa Jan 20, 2008
    My computer (Dell Dimension 8200 ) will not boot at all. It will turn on and go to the Dell Signature and then to a screen saying a recent software or hardware change may have caused this. When trying to load normal or safe mode it will go back to the dell signature. I have tried to restore with disk and to reload Windows XP but still goes to the same screens as above. I really dont want to lose everything I have on there and any suggestions will be helpful.
  • Anonymous Mar 21, 2014
    when I push the start button it does nothing....the light remains on, the wireless lights white,no monitor reaction even flash or something, ventilator is running, HDD is working.....I hope it's not the ATI chipset
  • Anonymous Mar 30, 2014
    wont power up.
    says battery is full.
    fans wopnt even start up its dead :(
    New Friend:
Im having the same problem, at first my keyboard went dodgey and it randomly switched off and now cant get it back on, when the charger is plugged in, no lights are on and nothing happened when i drained the battery. Havent tried the RAM thing, will try it and see
Posted on Feb 10, 2013
  • app_3rp46426
    app_3rp46426 Feb 10, 2013
I ran into the same problem with my Armada E500. In my case, it was a faulty RAM module. What I would suggest is start by removing the battery, and the charger. Then continue by removing the plastic section above your keyboard (there is a single screw holding it in place on the rear end of the laptop. This plastic covers the right-hand hindge) from there, there are four plastic tabs that you slide down to remove the keyboard. This will give you clear access to the ram. Remove the module(s) and, using a soft eraser, gently clean the contacts. If your laptop has two sticks of ram, I would also recommend putting them in opposite ram slots. After that, replace the keyboard and plastic bezzel, reconnect the battery and charger, and try to boot it up again
Posted on Sep 15, 2007
    Sergeant:
  • 457 Answers
Nothing is booting ......when in earnest I say that is the BIOS screen at the beginning not going too. When you say the lights all go but the computer does not BOOT can you clarify please what goes. Now you say the processor fan does not work I imagine you are INSIDE the unit to know this try pushing down on the CPU firmly with your hands it may have dislodged slightly it can do this sometimes.....Ive seen it happen. Now for the not booting I need to know what is if any?.
Posted on Sep 06, 2007
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
WE HAVE JUST HAD A LIGHTENING STRIKE AND ALL POWER IN THE HOUSE WENT OFF WHILST MY ASPIRE E 700 WAS POWERED AFTER THE POWER CAME BACK POWER LIGHT WAS LIT BUT COMPUTER WONT START UP WITH START SWICH
Unplug everything from the laptop, remove the battery and let it sit for 5 minutes. Replace the battery only, not the power brick and see if it will boot.
Does the power brick have a solid green light? Flashing? Red?
If it will not boot off the battery or power brick it may be fried.
Jun 28, 2011 | Acer Aspire E700 PC Desktop
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Start wont load window, just flahing light on screen. may have got virus
Remove hard drive, find out make and model of hard drive. Go to hard drive manufacturer's website and download testing software (if you have another computer with internet access). Should be a bootable ISO file. Burn the boot cd and run it on the host computer after reinstalling the hard drive. Sounds like a bad hard drive in my opinion.
Feb 20, 2010 | E-Machines eMachines W2686 PC Desktop
Computer wont turn on orange flashing light on the power button
Here is a web site that may help solve your problem.
http://www.randomfix.com/2007/04/19/dell-dimension-%E2%80%93-flashing-orange-power-light/
Oct 23, 2009 | Dell Dimension E510 PC Desktop
The charging light flashes on my toshiba l30 but computer doesn't start
could be anything from a bad adaptor to a bad battery , how ever sometimes the fan is pluged with dust ,blow on the fan and see if you get the fan started ,the computer wont start without the cooling fan on to protect the processor
Apr 10, 2009 | Toshiba Satellite L305D-S5904 Laptop
I have a acer travelmate 290 and when i push the power button he start and right after this the processor stop (wont boot) and the light of the cd at the top of keyboard stay open please help me...
It could be many reasons. But worst one could be CPU fan failure. If your CPU fan is not working properly then your computer wont boot but most imp thing is, it could damage your processor coz of overheating.
Another reason may be faulty ram, motheboard problem, hardware failure etc.
so cant say for sure but make sure ur fan is cooling ur processor.
Hope it helps
please rate
Sep 26, 2008 | Acer Computers & Internet
Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
May 05, 2008 | Computers & Internet
Compaq Armada E500 Notebook Logo
195 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
