Question about D-Link Express EtherNetwork DI-604 Router
Di-604 cable router
I followed the hook up instruction till i got to the part where it said enter "admin" for user in the install manual but it kicks me back and wont go any further please help!!
  • dlw1 Jan 28, 2008
    i was given a D-link 604 router by a family member. i successfully registered the router at the wizard website. But i am forced to 'unhook' all of the router cables from the hard drive tower, modem, and router. Now i can't register this router to my home computer. i have a miscrosoft windows xp home edition hard disk in my tower. qwest is my DSL broadband internet service provider.
  • 12,061 Answers
What it means is, when you are to log on to the "Router" so you can configure settings, you must put the word admin in BOTH logon & password boxes. Then one can configure the settings as required. After your router is connected to ya PC it has an "Address" when you open up your browser and type in the routers address, (often, 192.168.1.1) ... a box will/should then pop up and ask for logon and password... thats where you enter admin & admin then you will be Logged On to the router and your away...
Posted on Sep 05, 2007
SOURCE:
I have a D-link (Broadband VPN Router) that I want to hook up but I don't have the software. Is it possible to get free software downloads? The model #: DI-804HV.
Hello there,
You don't need a software for this one of the connection only requires an ethernet cable. What you need to do is to hook up the cable and then connect to the router locally. You may have to refer to the manual but usually you access 192.168.1.1 or something alike.
Apr 09, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
Where can i get the driver for Di-604 for a win 7 64bit OS
Routers don't need drivers. You connect to it via LAN using a LAN cable.
For further instructions, check manual at http://www.netwood.net/support/manuals/D-Link_DI-604_manual.pdf
Jan 14, 2011 | D-Link DI-604 - 4-Port Broadband Router [...
When i run wisard it ask about old passworld
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-774, and DI-784.
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The username is admin and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 4 To change the administrative password, enter a new password in the Admin section.
To change the user password, enter a new password in the User section.
Step 5 Click Apply then click Continue to save the settings.
Note: If you forget your password, you can reset the unit to factory defaults.
Click here for instructions.
Nov 02, 2010 | D-Link AirPlus DI-524 Wireless Router
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I have a d-link router, i need a password to it. how can i get a password
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
Userid and Password for DLINK DVR-628 Router
Select Admin and leave the password blank to enter the config settings
Jul 05, 2009 | D-Link DI-604 - 4-Port Broadband Router [...
Can't connect to web configuration
There is a reset known as a 30/30/30 reset. Hold reset with power on for 30secs, unplug power while still holding reset for 30 secs, plug power in while holding reset for 30 seconds more and release, wait 30 secs or more for reboot. This should put it back to factory defaults regardless of brand. Set your IP manually on the PC to be 192.168.0.2 Open your web browser and type in the IP address of the router (192.168.0.1 by default). Enter the username (admin) and password (blank by default), and then click Ok or Log In
Aug 26, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Internet problem connection.....
your computer has been set up to be the PPPoE account holder for the modem. if you have a router, you will need to configure the router to login to the ISP account using the PPPoE information so that your router is the account holder for the modem, then you will be able attach multiple computers to the internet using the router.
Jun 21, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Help me Please
D-Link's default login should be "admin" and the default password "password". Try logging in with that.
May 01, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
How do I change the administrative/user password on my router?
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin and the password is blank (nothing). Click OK. Step 3 Click the Tools tab and then click Admin to the left. Step 4 To change the administrative password, enter a new password in the Admin section. To change the user password, enter a new password in the User section. Step 5 Click Apply then click Continue to save the settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
D-Link Express EtherNetwork DI-604 Router Logo
116 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
