Question about Motorola Mobility A768i Cellular Phone
Motorol a760 charging pin track damage
Hi.. my motorola phone a760 has charging track damage from PCB please help me to fix this problem thank u in advance
0 characters
1 Points
How to reset my motorols bt51 with the unlock code forgotten ?
Just type any password until your phone asking PUK code. PUK code is a unique number to unlock your phone if you forget your pin number and can be found from your sim card paper or asking from network provider. With puk code you can unlock motorola bt51 from old pin and you can set new password, but please pay attention when you entering that code don't make mistake for many times. It will not make your motorola unlocked your sim card also locked.
Aug 06, 2011 | Verizon Communications Motorola w385...
User manual for the motorol droid, not the II
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Thanks for using FixYa.
Sep 17, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Motorola startac st7868w only transmits with earbud & ext mic -
dear vjmusa ,
step 1 : open ur cell phone .
step 2 : check clearly the pcb board either any damage or not
step 3 : check the components of the pcb.
step 4 : most probly the small tiny capacitor might have broken .
step 5 : check with multimeter so that u can recognize the connectivity of the circuit board
check with the buzzer .. might have loose contact with the surface of pcb
or just do small scratches on the pcb , where the buzzer touches ..
so that it will get the connectivity and works fine ..
Jan 02, 2009 | Motorola Mobility StarTAC ST7868W Cellular...
Motorola i870
One or more part are getting hot in your phone due to short circuit. Water damaged phones normally have this problem. Battery gets charge but it discharges quickly for that leakage. You can try yourself. Disassemble the phone. Put out the main PCB and connect Battery. Now observer which parts are getting hot. Clean the PCB properly and change that parts if you can.
May 19, 2008 | Motorola Mobility i870 Cellular Phone
Motorol L6 SLVR Batter chargers
you are actually able to use any charger thats fits
but i warn you do not keep switching chargers all the time just stick to one charger for the mean time as it can damage your phone :D
hope this helps
Feb 29, 2008 | Motorola Mobility L6 Cellular Phone
Motorol V3XX
Either the technician didn't actually change the keyboard flex or you have water damage on the phone.
Jan 16, 2008 | Motorola Mobility RAZR V3
Motorolal razr phone AT&T
the both the inside and outside screens
are blank?
what do i do cause i NEED my phone!
Dec 05, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Razr V3i charging problem
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
May 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility A768i Cellular Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
