Question about Panasonic Lumix DMC-TZ3 Digital Camera
Windows XP won't recognise the camera
I can't get Windows XP to recognise the camera using USB connection. CAn anyone help?
  • Sandybones Sep 08, 2007
    dinoza,
    Unfortunately this didn't work. There's no network drive involved and I suspect now i have a problem with the USB drivers. XP does not recognise the camera which should really be a plug'n'play function. i'm tearing my hair out down here, but thanks anyway for your assistance.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Let me know if this helps: When a mass-storage class (MSC) Luminx camera is connected to a Windows XP system the camera does not appear as a mounted drive if there are no free drive letters between physical drives and mapped networked drives. Remapping the first network drive and leaving a free drive letter solves this issue. For example: If the Floppy Drive is drive ?A? the internal Hard Disk is ?C? the CD-ROM is ?D? and the mapped network drive is ?E? the Lumix camera will not mount. If the mapped network drive is moved to ?H? the Lumix will mount properly as drive ?E?. To change the drive letter mapping: Find the mapped network drive in the "My Computer" Right Click the drive and choose "Disconnect" Use the "My Network Places" to find the share to be mapped (that was removed above) Right click the shared item and choose "Map Network Drive..." Choose a drive letter from the pop-up list, remember to leave at least one free letter after the last physical drive Click "Finish" the share will now be mapped to the new drive letter and the camera should mount As long as there is a free drive letter between the last physical drive and the first network drive the actual letters do not matter. For instance if there were more than one hard drive (or DVD, CD-R, etc). This issue has only been documented with Windows XP and MSC class cameras, cameras capabale of using PTP USB mode should be set to PTP to avoid this issue.
Posted on Sep 05, 2007
  • Dinoza
    Dinoza Sep 08, 2007
    Just one last question, have you tried uninstalling the camera's driver and try again by restarting computer and plugging in the camera?
    Sorry I couldn't help.
    You can mark this answer not helpful and hopefully another expert will come to the rescue.
SONY DCR-TRV22E CONNECTING TO WINDOWS 7
after extensive searching I can't find a usb driver for windows 7 . Unfortunately the maker no longer supports later than windows 2000 for their driver. You might be able to run vmware and pretend to have an operating system that is an earlier version like windows 2000 or XP and run a driver in it for the pretend operating
system .
https://esupport.sony.com/US/p/model-home.pl?mdl=DCRTRV22&template_id=1®ion_id=1&tab=download#/downloadTab
https://www.vmware.com/au.html
https://www.vmware.com/support/ws5/doc/ws_newguest_setup_simple_steps.html
I do not think this camera has firewire
but it may have a memory stick
maybe you could look at if you can get a memory stick reader that suits its memory stick.
Feb 23, 2018 | Sony Handycam DCR-TRV22 Mini DV Digital...
I need a installer for my dcr-trv22 nstc
I HAVE SONY DCR-TRV22E, AND HAVE WINDOWS 7 ON MY LAPTOP (HP G72). WINDOWS DOES NOT RECOGNISE WHEN I TRY TO CONNECT VIA USB. CAN ANYONE HELP ?
I HAVE READ SOME POSTS SUGGESTING USING A FIREWIRE CABLE - NOT SURE MY LAPTOP HAS THIS CONNECTION - COULD ANYONE EXPLAIN..
THANK YOU.
Nov 23, 2011 | Sony Handycam DCR-TRV22 Mini DV Digital...
Cannot download photos to my pc
For the camera to be 'recognised' by Windows, you need an USB port with a correct driver installed (should be automatically in Win XP SP2 and later, Vista, Win7, ...)
Then you need a 'good' (tested) USB cable to connect to the PC.
The OS should detect a new USB device after connection of the camera AT the MOMENT the camera is switched ON ...
Nov 12, 2009 | Canon IXUS 960 IS Digital Camera
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
PC does not recognise Camcorder when connect via USB Cable
my pc does not recognise my camcorder gr-d63 when connected
Dec 28, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
My USB device is not recognised
try to plug it to a fresh windows xp. install your driver and i think that would be recognizable by your computer. i had the same problem just like yours with my computer but after i format my pc and installed a new windows xp service pack 2 with other drivers, it is now detectable. hope that helps!
CHARCOIS
Jul 28, 2008 | Sony Handycam DCR-TRV17E Mini DV Digital...
Sony Handicam DCR-HC40E not getting recognised by Vista
Hello
I found a solution installing the generic Sony USB driver in Vista Ultimate using compatibility mode (Windows XP SP2).
Mar 12, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
My canon S5 IS is not recongnized by Windows XP in my PC
i am afraid this is a microsoft O/S issue. It will not allow 2 imaging devices with twain drivesrs to be recognised at the same time. You have to disconnect one at the usb plug before the O/S can see the other one.
I have a scanner with twain drivers and XP will not recognise my S5 IS until i unplug the scanner. The O/S is recognising the camera as an imaging device rather than a usb mass storage device like for my other cameras.
Either MS need to fix this conflict issue or Canon need to reconfigure their drivers.
Jan 11, 2008 | Canon PowerShot S5 IS Digital Camera
USB problem
i think u must upgrade the USB driver on ur pc go to this link and download the driver and save it in desktop and double click on it and install it
http://usb-1394-firewire.free-driver-download.com/SIIG/31991/SIIG-USB-2.0-Controller-Driver-v0.216-Windows-98SE-ME-2000-XP.html
rate me solved if its help thx
Oct 30, 2007 | 2wire 1000-200004-000 Network Adapter
Panasonic Lumix DMC-TZ3 Digital Camera Logo
131 people viewed this question
Top Panasonic Cameras Experts
Jay Plesset
cesarakg
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
