Question about Explorer Appliances GRQ10 Top Freezer Refrigerator
Odors from gas fridge
Our Explorer fridg is maybe 5 years old. It is in a cabin at 5000' in elevation. When we experienced fumes, we had the gas comapny man out to service it and he ordered the smallest orifice he could get and installed it. Did not correct the problem. He manually made the orifice smaller....stillwe have unpleasent odor. He tells us it's because of the elevation, not enough oxygen, that it burns rich and we have odor. I refuse to believe that we paid over $1500 for a frig that we can't use. It has been unused for the last 2 years. HELP, what else
  • Carolyn Stout
    Carolyn Stout Sep 05, 2007
    We will give it a try. If it does not solve the problem, would it be okay (saftey) to move the fridge outside on the porch or deck?
    If so, at least the fumes would be outside and when we'd still have our cold storage.
  • Carolyn Stout
    Thank you Dyllan.
    Sergeant:
  • 279 Answers
Unfortunately, your gas man was largely correct. At higher altitudes you need to reduce the gas flow to compensate for the thinner air, and therefore smaller quantity of oxygen. Eventually, you reach a breaking point, where there isn't enough gas to run the appliance. However, it is entirely possible that, while he had the theory right, he was incorrect about not being able to make this work. If it still smells, you need a smaller orifice. Whether the refrigerator will work with a smaller orifice, I don't know. If you really want to give it a try though, make sure that gas line is off and remove the orifice that's on there now. Then take it to another gas repair man (I'm sure you can find one in the phone book) and explain the problem. If he can get a smaller orifice, you're in business. If he can't, it's likely your gas man was right and there's nothing you can do.
Posted on Sep 05, 2007
  • John Goodman Sep 05, 2007
    Okay, I'm not a safety expert when it comes to gas lines, so I can't say this authoritatively. However, I think it would be safe. We've already determined that it has a very small nozzle, so it's not leaking a lot of gas. Also, the air is thin, which further decreases the chance of explosion. Having it outside, I would THINK it would dissipate enough to be safe.
    However, I suggest getting a second opinion on that.
    You're welcome.
    (don't forget to rate my answer)
Customer service phone number???
Clean the hose out at the back of fridge going down into catch tray, it probably blocked.put vanilla essence in fridge to get rid of odors.
Dec 23, 2014 | Refrigerators
Gas fumes inside cabin
You may have a defective vapor recovery system or a loose hose coupling between the filler and the tank. The recovery system can go bad after a lot miles/time. Also, overfilling the tank (going beyond 'one click') can damage the system.
I would replace the gas cap first, make sure it is the right kind, before having the VR system checked.
Apr 18, 2014 | 2008 Honda Ridgeline
When on gas smells of exhaust fumes in van and
sounds like the burners need a good scrub to clear carbon off jets.
May 07, 2010 | Thetford Norcold DE0051 Refrigerator
I have a 22 yr old top freezer fridge. I took it to my cabin last year when I bought a new one for the house. However, it does not work-get cold at all. We don't leave the electricity on when we are not at...
ok Sounds like a place i would love to go but .... First, if the trip to the cabin was very bumpy chances are it sprung a leak and lost its gas charge , if this is the case , repairing it may cost more than replacement depending on the location of the leak , if the trip up to the cabin was smooth then consider this, When moving it around to load it up did you maybe move it around suddenly , and if you did this too would cause a leak specially considering  the age of the system, chances are its lost its charge and would require leak testing and repair , here in Australia anywhere up to $ 600.00
May 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer has bad smell, cleaned entire fridge and freezer out, no help. working fine but smells ?? side by side model about 5 years old, maytag
For odors in the refrigerator/freezer try baking soda or, for tougher odors, try Fridge Aid deodorizer, also available in the accessories section of our website. on  www.repairclinic.com
Mar 31, 2009 | Hotpoint HSS25GFP Side by Side...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Fridge freezer not reaching operating temperature
maybe its time your fridge to go to the service center. 5 years is a long time yaknow. have them check for the freon as it might have runned out.
Jan 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Explorer Gas Refrigerator
I have a 12 cubic foot explorer and have found that if the burner is not keep clean the effiency will go down. I also found that adjusting the flame to the lowest temp does not keep the fridge the coldest. Adjust the flame until you get an even blue flame with minimal yellow in it.You make the adjustment with the temp control.Also clean the chimney, I use a gun cleaning kit. Thanks Dennis
Jul 14, 2007 | GE GBS22HCP Bottom Freezer Refrigerator
Explorer Appliances GRQ10 Top Freezer Refrigerator Logo
100 people viewed this question
Top Explorer Appliances Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you an Explorer Appliances Refrigerator Expert? Answer questions, earn points and help others
