Question about Samsung HCN653W 65" Rear Projection Television
Need help calibrating
Well this the problem. a few months a go I had to call sears because the set would not turn on. They replaced two boards and and fix the problem but left geometry a little off. the repairman told me call him back in a few days for him to finish the calibration. well, I didnt I thought it was too easy to do and I grabbed hold of the service manual and changed alot of stuff. the set is now completely messed-up ( bowed letters,skinny people, a complete mess) I was hoping that maybe someone with the same set can get into his service menu and tell me the values in each of the submenus starting with all the values in "deflection" and son on... I know is much to ask but I do not have the money to have a professional come and do it.... thanks
  • 1 more comment
  • candu Sep 05, 2007
    Sorry I forgot to tell what type of set it is.
    HCN653W
  • Anonymous Mar 14, 2008
    default deflection values for samsung tv ct-21z57mq
  • Chase Lindsey
    Chase Lindsey Mar 20, 2009
    ok so the values are different for each set, if we get together and trade numbers we might be able to get it srriaght
You say that they replaced the Mainboard 2 times on this model? I had the same exact model and they came out and replaced the Mainboard and 2 other parts 4 times. Under the lemon policy warrantee at Bestbuy, I am now (finally) able to replace the TV with a Mitsubishi WD-65733. This TV is a "LEMON" if you can, "GET RID OF IT!" I understand your frustration completely and know exactly why you finally took matters into your own hands and tried to fix it yourself, it's because it's a piece of total "JUNK!"
Posted on Sep 19, 2007
    President:
  • 3,130 Answers
Thats why the service menu is for the SERVICEPERSON! It tells you in the manual to always write down the values. Even if you get someone with another set, that could mess up your set even more as there is no "default" settings to these alignments. Even with the same exact set, same exact model, the settings could be way off for one but not for the other. I am sorry to say, if you cannot straighten this out, you have no choice but to call a pro to help you out. Good Luck
Posted on Sep 05, 2007
  • Larry  Dillon
    Larry Dillon Sep 15, 2007
    My magic wand does not work through the Internet.
  • Larry  Dillon
    should be CANTDO LOL
SOURCE:
My screen turns green and no sound
This could be in the main processor board, or in the display substrate itself. The service rep would test by trying out boards until he gets to the fault. After board replacement he would check any recommended calibrations, and then return the set to the customer. If the set is more than a few years old, it may not be possible have new boards.
Jerry G.
Jun 25, 2012 | JVC LT-32X576 32 in. LCD Television
Error 7
Incline calibration is necessary when: the display shows ERR7, the drive board incline error LED ( LED5) lights or the incline has extended beyond its normal rangeThe goal of calibration is to synchronize the incline set mechanically and electronically. Mechanical calibration sets the incline motor pipe to the 0% position. This happens when the red line on the thin pipe is even with the end of the thick pipe. Electronic calibration sets the variable resistor (VR) value to the 0% position. This happens when the voltage across the VR blue and green wires is 1.20 VDC.
Readings of VR voltage (blue and green wires) should show around 1.20 VDC at the lowest position and around 3.80 VDC at the highest position. If the VR looses calibration or cannot be set to 1.20 VDC, replace the VR. If the incline motor gets voltage from the drive board but fails to operate, replace the incline motor set. If the incline fuse blows again and again, replace the incline motor set.
Jan 19, 2012 | Sportsart 6300 Treadmill
Touch screen did work 4 a few days,but its not working now.the rest of phone works
Touch screen problem
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jul 18, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
My touch screen quit working
If the touch screen of your phone keeps working, then it means the sensor board of the phone is bad and need to be replaced, if you can access the menu of the phone, then you need to calibrate the screen first.
To calibrate the screen, you need to go to the menu, then you select settings, then you select calibrate screen then you follow the rest of the instruction from there on.
If calibrating the screen does not help you, then it means you have to fix the sensor board of the phone, if your information from the keypad reaches the screen, then it means you simply need to replace the touch sensor board of the phone.
Hope this helped.
Take care and good luck
Jan 10, 2011 | Samsung SGH-A877 Impression Cell Phone
We have tried everything to try and get the board to calibrate and can't get it to work any which way what should I do? It is the tony hawk shred board and game.
  • Be sure your board is a few feet away from any walls, furniture or other people.
  • Replace the batteries in your board (even if they were new).
If those didn't help, you can check the Answer Page specific to your platform:
Calibrate Wii: http://ow.ly/PUt7
Nov 20, 2010 | Nintendo Wii Console
I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Jul 14, 2009 | Exercise & Fitness
I own a Mitsubishi WS65869 it has not been working for a few months now. All I remember is shutting off one day a green blinking light started and does not turn on anymore. Can you give me some idea to...
Hey There,
It sounds like you either have a bad DM power board or a few caps (capacitor) are blown on your board. If you are comfortable with soldering then you will need to replace your Caps which are 1000uf 16V 105C and I would replace all of them ($1.25 ea). I found this great PDF online to help (this is not your model# but it expalins where and what your DM Power board is located) If not, Sears Parts carries DM Boards for your Mitsubishi - call in your Make/Model# and tell them you believe your DM power board has gone bad. The board should cost no more than $50-$70. Replace the board and let the TV blink for about 30-45 secs and it should turn on. If you decide to take it to an electronics shop, unless you know the owner, prepare to spend anywhere from $800-$1100..
Good Luck and Happy Holidays..
Dec 19, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Haier 42EP242S Problem
too bought a Haier Plasma 42EP24S ,it stopped working after 7 months -I moved and did not touch it for the next five months
while searching for another tv to replace it- I came apon this site .
the tv was out of warrenty by both sears and haeir
well after reading these posts I called haier america and complained they in turn extended my warrenty and a sears rep came on 5 differant times and replaced all the boards inside tv with no luck - so after putting in over $1400.00 in parts an repair into a $1200.00 tv they wanted to start replacing boards again
I refused and kept complaining to several differant reps at sears
[they told me it was haeirs responsabilty not thiers] I don't know haw many times I explained to them that sears sold me the tv not haeir so stand behind what you sell -well after alot of calls and persistance sears replaced my tv free of charge with credt for a new tv for exactly what I paid
SO DONT BUY ANY PARTS OR PAY FOR ANY SERVICE IF YOU BOUGHT THIS TV AND ARE HAVING PLOBLEMS
be persistant untill its either fixed or replaced
Dec 10, 2007 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
POS TV?
Nov 22, 2007 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Power on problems
Having to press the power button multiple times before the set comes on is usually caused by low standby voltages in the power supply or bad connections on the printed circuit board. The "D" board is not your problem. Most likely there is bad capacitor in the 9 volt standby supply.
Nov 14, 2007 | Televison & Video
Samsung HCN653W 65" Rear Projection Television Logo
156 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
