Question about Zanussi ZSS7 / 5W Compact Refrigerator
Ice Dispenser not dispensing
I have a Whirlpool Gold Conquest refrigerator model GS6HEXNS00. We recently had rolling power outages in our area and since then my ice cube dispenser does not work. The crushed ice dispenses and the water works as well. I have tried unplugging the fridge to maybe reset it but nothing seems to work. Any suggestions?
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 1462 Answers
SOURCE: Ice build up on back wall of bottom freezer unit of Kenmore fridge
back panel removes.
problem is that defrost system is not working.
check defrost heater and thermal cutout in series with heater.
if those ok, then problem is probably with main module
Posted on Jul 06, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
  • 39 Answers
SOURCE: only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Posted on Jul 15, 2009
MY ICEMAKER IS STUCK IN THE CRUSHED ICE CYCLE WONT PUT OUT THE CUBED ?? EVEN WHEN I PUSH THE BUTTON BACK AND FORTH WONT SWITCH ??
if you have selected cubed on the door and still wont dispense cubed ice likely cause is the cubed ice solinoid( located behind the panel in where the auger motor is located) thats the motor that turns the curly thing in the ice cube resivoir.....!!!
Jun 08, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Conquest Defrosting
Contact the dealer/Store you got it from, it should be under warranty. Without being flippant, make sure it hasn't been turned off by mistake at the wall.
Oct 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Crushed ice does not work but cubed ice works as well as water.
pull down and turn the pole that fits over the bar. This should work. If it is not changing by itself, then the solenoid will have to be replaced
Jul 09, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator icemaker does not dispense ice cubes
I don't think the ice maker liked the water being turned off. Usually there is an arm that will raise up to a catch position that will turn the ice maker off. I hate to say it, but ice makers are best to replace than repair. The internal parts are difficult to change, and with a new one you will have no problems. They are not too hard to change. Shop around for a good deal, I use e-bay.
Apr 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker
That means that the solenoid that controls the ice maker is defective and must be replaced with a new one.
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Jul 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL REFRIGERATOR
my refrigerator gold is running but not cooling I have the model number and serial numbers if that is helpful please help
Apr 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Zanussi ZSS7 / 5W Compact Refrigerator Logo
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
