Question about Epson Stylus C84 InkJet Printer
Epson cx2900 3 in 1 printer
My printer cannot print..i put cis in 3 months...all ink are full i try several cleaning the print head..but no print happen..pls..help me my problem..my printer is 3 months when i buy..thanks.. teng6
  • 5 more comments
  • kerrimatthew Dec 13, 2007
    will print every color except black.  12 cleaning head cycles.  two new black in cartridges.  any ideas?
  • Anonymous Jan 02, 2008
    Prints only a few words of text .Horizontal alignment: All blocks show identically only 4 black lines of different width. Nozzle check:interrupted lines. Cleaning nozzle action : incomplete.
  • Anonymous Mar 02, 2008
    i used CISS in my epson cx2900 for about 6 months. then, the yellow color stopped being detected. i changed back to genuine ink. no error detected in computer and maintenance programs.
    it mechanically prints like normal, BUT NO INK IS PUT INTO THE PAPER. meaning NO OUTPUT IS PRINTED IN THE PAPER.
    why is this so? any help pls? a million thanks in advance.
  • Anonymous May 12, 2008
    My printer started skipping half lines and eventually stopped printing at all. It prints some black sort of faded in color. I replaced all the ink cartridges...still won't print. I forget how to access cleaning directions.
  • Anonymous Jun 01, 2008
    Printer won't print...I think the inkwells may need to be cleaned and I don't know to do that. The ink is not getting through. I replaced all ink cartridges.
  • scoopsam Aug 08, 2008
    The machine won't print. I tried cleaning the ink wells. Changed all the ink cartridges.
  • Anonymous May 11, 2010
    now, all the lights are flashing in my epson cx2900 printer. i used SSCSERVE.EXE version 4.30. i clicked on all of the features there.
    i don't know which caused all lights to flash.
    also, my black ink is new, yet it says the black ink is empty.
    New Friend:
My Epson TX110 can't print when it turn to CIS. how to solve this problem?
Posted on Mar 16, 2010
If all light flashes and your CX2900 is converted to CIS might as well bring it back to where you bought your CIS. maybe they have the software for resetting the waste ink pad counter.
Note: SSCServe wont work...
Posted on Mar 03, 2009
    Sniper:
  • 66 Answers
Proably is the waste ink pad saturated and the only solutions is a adjustment program to reset the waste ink counter and it almost impossible to clean the head manually
Posted on Mar 17, 2008
  • Anonymous May 09, 2008
    if all light flash it means a fatal error and proably some problem with the carriage or mainboard
    Problem Solver:
  • 15 Answers
The problem might be the ink, change the cartridge maybe the ink dried out....
Posted on Sep 18, 2007
SOURCE:
Magenta ink not display
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 22, 2013 | Epson L200 Original Continuous Ink Tank...
I have an Epson RX680 the black and yellow ink are not printing after trying several print head cleanings and even replacing the cartridges (even though they were better then half full)
Nov 15, 2012 | Epson Stylus Photo RX680 Printer
My epson stylus t13 has color issue, it can print 'blue', when print blue it appear red. Please advice.
Hi!
Have you tried doing maintenance for nozzles? You can press and hold ink button for 3-5 seconds and it will run a head cleaning cycle. Try it 3 times and re-print.
Keep me posted.
Sep 06, 2011 | Office Equipment & Supplies
I have epson r230. In light magenta vertical lines appear, i run clean print head many times, but not resolved, in skintone green color appear. wht to do
In these situation you can try these procedure.
Take a empty cis . pour it with amonia solution ( water40% + amonia60%). set th CIS and run head clean. 2/3 times. put off Cis. set original cartrige/ CIS with ink. Run head clean.1/2 times. print a nozzle cheak. I Think you may relive from your problem.
Thank you.
Jun 28, 2011 | Epson Stylus Photo R220 InkJet Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
My printer won't print it sat for 6 months we put new ink in and it scans and goes through the actions but doesn't print ink
The problem with printers like Epson is that they cannoy stand without being used for that long. The print head that is largely responsible for print quality is built into the machine and the last ink that passed through 6 months ago is hardened inside. Dry several deep cleanings with nozzle checks inbetween. You may need to send it for manual print head cleaning with a printer technician.
Feb 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Removing and cleaning Epson Printheads
I don't know how to remove the print head but if you want to clean it - check for mr.musculo solution from any market near you. Leave the print head in this solution (warmed at about 35 celsius) for several up to 24 hours.
Dec 03, 2007 | Epson Stylus Photo 950 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
1,204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
