Oki C5200n Print problem
When I print a demo page, everything prints well with great print quality. But at the bottom of the page there are 7 rectangular color boxes. These boxes look great except for the last three boxes which are red, green and purple. It looks like they have a yellow edge around the box. It looks as if the yellow toner is misaligned and therefore creating a yellow edge. I haven't hooked this printer up yet and I fear I have a bad printer. Please help! I also have another C5200n that the black print is really dark and seem to be blurred. seems like too much black toner is dropping. Please help!!! I have 2 printers that don't work correctly!
  • Anonymous Apr 28, 2008
    I noticed the same problem with the yellow some weeks back. Then the magenta and cyan also went out of line, but in another direction, and only on one edge of the paper. I tried cleaning the rollers, both input and output. The color alignment adjust on the machine's instrument panel seems to have no effect on output. Oki tech support wants me to send it away for repairs.
SOURCE:
mosesclive
  • 191 Answers
SOURCE: diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
  1. Press the Menu button.
  2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
  3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
  4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
  6. Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
  1. Power off the printer.
  2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
  3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
To print all four 20% toner test prints, perform the following step:
  4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. The test print will print.
  6. Press the Cancel button.
  7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  8. Press the return%20arrow%203100cn.jpg button. The test print will print.
  9. Press the Cancel button.
  10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  11. Press the return%20arrow%203100cn.jpg button. The test print will print.
  12. Press the Cancel button.
  13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  14. Press the return%20arrow%203100cn.jpg button. The test print will print.
  15. Press the Cancel button.
  16. Power off the printer and power back on.
Reseat the drum cartridge, perform the following steps:
  2. Unplug the power cable.
  3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
    Figure 1 - Open Front and Top Covers
  4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2 - Raise Lever to Release Drum Cartridge
  5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3 - Remove Drum Cartridge
  6. Insert the drum cartridge.
  7. Close the top and front covers.
  8. Plug in the power cable.
  9. Power on the printer.
Posted on Dec 20, 2007
SOURCE: Oki C5200n 002: Fatal Error
We have to change firewall settings in our Fios router. I just don't know which ports or udp to open.
Posted on Jan 08, 2008
SOURCE: printer driver
Hi All, After installing Leopard 10.5 I noticed that I was having problems printing from my C5200n OkiData printer. I contacted OkiData Support by email, within 2 days they emailed me back with a beta driver for the C5200n and it worked perfectly. So the solution is to email them from their support portion of OkiData website and they will cure your problem until the drivers are posted for the public.
[email protected]
Posted on Feb 18, 2008
SOURCE: Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Posted on Oct 06, 2008
  • 22 Answers
SOURCE: Print quality problems C3400n
And the problem is with the magenta drum.
Posted on Jul 24, 2009
Testimonial: "You answer was 'spot on'!"
127 borderless
You cant. laser printers (or led like oki) or more specifically dry toner electrostatic printers always have a margin to prevent the paper from jamming. the only way to print "full bleed" is to put paper in that is bigger than what you need, print the image, and trim it down.
Aug 14, 2014 | OKI C5200n Laser Printer
How do i clean the print heads on a oki c5200
With the top cover open, gently wipe the LED head(s) with the lens cleaner pad supplied with replacement toner cartridges. A soft, lint-free cloth with some isopropyl alcohol (rubbing alcohol)** can also be used.As the last step before closing the cover when replacing a toner cartridge or an image drum.
If you are experience poor print quality, including
- longitudinal white stripes or fading
- blurred letter edges
CAUTION! Do not use methyl alcohol or other solvents on the LED heads: this will damage the lens surface.
Nov 21, 2011 | OKI C5200n Laser Printer
My oki data C5200 in printing a faded picture along the right side of the page only. I have cleaned the print heads and checked the levels in the cartridges. Everything seems to be fine. Can you help?
> OKI C5200n laser printer
Take the toner-cartridge out, and gently tilt it left-and-right
to redistribute the remaining toner in the cartridge.
Reinstall it.
Oct 13, 2010 | OKI C5200n Laser Printer
When I print on my Oki Data printer I am getting a line down the middle of my page that is white I suppose because its taking my color away. I just changed the Fuser - how can I fix this - I have projects...
i would try and clean all the l.e.ds which are located as you lift the cover they are conected to the underneath run your finger along them and see if that helps.
Nov 10, 2009 | OKI C5200n Laser Printer
OKI C5650n USB port not working
Yes, well I can´t help you to solve that problem and in fact i´m hoping that you´ve already solven it, cuz right now i got the same problem with my c3450... It worked just fine under vista x64 but now on windows 7 x64 i have the same problem as you have/had!
Cheers
Jun 02, 2009 | OKI Office Equipment & Supplies
OKI C5200 laser printer
Delete driver, download latest from oki, reinstall, is this networked or USB?
Is printer free from error lights, check page settings.
more I think about it, it seems to be a network/driver issue.
If printer can stand alone print ok ie menu map, then it is either the cable but more often the driver.
Check IP config if network.
Fixya or post back
Jan 02, 2008 | OKI C5200n Laser Printer
Printing with 190gsm paper
Max paper weight is 203gsm so you are near the upper end of specs, you must feed via manual pass and exit from face up tray (out of rear), paper type(heavy/card stock) must be set on print driver. User guide can more than likely be found www.oki.com.
Dec 31, 2007 | OKI C5200n Laser Printer
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual: http://www.feedroller.com/Store/Service%20Manual/50_53_5600.PDF
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
Printing problem
try re-installing or updating the printer driver
Jun 07, 2007 | OKI C5200n Laser Printer
Open Questions:
144 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
