Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Troubleshooting it won't go to av1
  • 375 Answers
Re: troubleshooting
Did you set the sub menu's feateres for inputs.
Posted on Sep 05, 2007
0 characters
3 Points
How do I find AV1?
AV1 is video one and use source or input to get there---if set does not have the audio and video input jacks on it no connection that way is possible.
Apr 26, 2012 | Projection Televisions
How do I connect a mitsubishi dvd player to a 60 inch mitsubishi tv?
At the back of your tv you will see a lot of connectors try to look for audio video in it has a label AV1 in or AV2 in etc. choose what slot you want to use and when using the DVD set your tv on what slot you use, example AV1 in set your tv to AV1 using your remote control. Good day and best regards.
Sep 11, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Can't get a picture - Turn on TV - put DVD into player - with rem
first of all, is it on the correct av channel, plugged into av1 and av1 selected on the tv.
is the lead good, can you swap around some leads with other known to be good leads.
are the leads pushed in fully, a scart lead can sometimes look like its pushed in fully when its not.
check for bent pins on each end of the leads.
Mar 22, 2010 | Projection Televisions
Cant get AV1 symbol off top left hand corner of screen
hello on the remote control theres an button with an i symbol try pressing tv then the i button it should clear it
Oct 15, 2009 | Projection Televisions
Does the S/H TV have AV1 & AV2 settings and a scart socket? If so just connect the a scart lead from Sky box to TV and select AV1.
If you have no scart socket on the TV you need to connect a coaxial (aerial) cable from the sky box to TV and tune in to a channel. It is possible to tune in your sky remote if you have the TV code.
Please remember to rate this solution.
Oct 22, 2008 | Projection Televisions
I connect my two vcrs and i press record but then when i push play on the recored tape its just black
Are you connecting via scart? If so the VCR doing the recording has to be set to Line 1 or AV1 this can be done on the remote by selecting the source button or using the channel up and down buttons in the display the channels 1,2,3 etc will go to L1 or AV1 you should then be cable to copy assuming the video is copyright free if not Macrovision protection will prevent copying.
Oct 02, 2008 | Projection Televisions
Model 60PL9200D/37 no sound
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Apr 07, 2008 | Projection Televisions
No sound
I suppose you have a surround sound system that is now not functioning? They must have disconnected your audio out cables from your television to your surround sound system. Make sure your main audio out channel on your television is connected to AV1 in on your surround sound system. It is probably an RCA cable (red and white). Then when you play your TV, make sure the audio is set on AV1 for your surround sound system by pressing the function button until AV1 is on the display. Let me know if this helps.
Dec 26, 2007 | Mitsubishi WS-48311 48" Rear Projection...
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
