Question about Philips 60PP9200D Television
NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
I have a phillips model # 60pp9100d/37 60" rear projection tv. Bought new 18 months ago and it was stored in climate controlled room for 8 of the 18 months but is now out of warranty. PROBLEM IS: when pressing power button on tv, the button flashes green 2-3 times, without any picture or sound on the screen. problem started with tv shutting off on own and after being off for awhile it would turn back on, only to randomly just shut off. any help is very much appreciated. thanks
  • 1 more comment
  • trompuda-19 Aug 30, 2008
    NO POWER NO PICTUTE NO SOUND BUTTON POWER IS FLASH 3 TIME
  • nelleigh Jan 04, 2009
    Philips 60pp9200D my TV blinks when the power button is pushed, but it doesn't turn on. it blinks 3 times and stops for a few seconds and then 3 times and keeps doing it
  • Anonymous Mar 28, 2009
    Where do you get the TV software? I have a similar problem and would like to try.
  • Philips Master
  • 3,459 Answers
I had the same problem also. It was the optoic. You can get a repair kit from www.magnavoxhelp.com
Posted on Jul 17, 2008
  • 4 Answers
Had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
Check the wires inside at the left lower region as you are looking at the rear. There are several circuit boards there that tend to loosen when moved. The cables are really ribbons like those used in computers.  I'd lioke to be more specific however I'm not entirely familiar with this model, just rear projection tvs in general.
Posted on Oct 21, 2007
SOURCE:
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
No sound-power switch on T.V. flashing 9 times
May be a bad optoIC. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Oct 05, 2006 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9200D Television Logo
929 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
