Back to:
Tags:
Kitchen Ranges
Generic problem for all Kitchen Ranges
Oven will not heat up (by 4 users)
posted by rob381 on Sep 05, 2007
On 9/03/07 we ran the self clean on our kenmore 9242 and now the bottom heat element doesn't work. Everything else is fine and no error codes come up. The wires and element seem to Ohm out fine.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by tranzor Z, posted on Sep 06, 2008
Same issue. We used the self oven cleaning and about 1 weej later the bottom burner won't light. I appears that the igniter element went bad. Any ideas on how to replace it? The model number is GE Profile JGS968SHSS and the over is 4 years old.
Comment by GE bad, posted on May 27, 2008
After turning on the self clean feature went to use our nice clean ioven and it will not heat up. The broiler and range top work just fine but not the oven.
No fault code and oven light goes on it just won't heat up.
It is a GE XL44 and it is about 8 years old. No problems before this point.
Ian
Comment by Guest, posted on May 11, 2008
Same problem here. i dont know what it is
Solution #1
posted on Jul 04, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
same problem here. Looking for solution..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Oven will not heat up:
I don't want to Accept this solution
Solution #2
posted on Sep 23, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
we have the same problem. Broiler ignites fine and turns on and works fine but the bottom will not come on.
AS POSTED BY: JSROCK516
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Thank You!
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
Hi Our Belling formula multifunction oven has stopped...
Cannon 10476G Dual Fuel (Electric and Gas)...
how to remove the pan support on a cannon cooker to enable...
Frigidaire FEF364DQ Electric Kitchen Range
The range clock got stuck at 3:35 and the oven will no...
Tecnik TKC1285 Dual Fuel (Electric and Gas)...
Can anyone tell me how to remove the main oven back plate...
Kitchen Ranges
I need installation instructions for a Belling 112WGR -...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
