Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Will not power on
Problem started with tv shutting down by itself and then unable to turn back on. after extended time, the same problem occurred. now when the tv power button is pressed it flashes green 2-3 times and then nothing, including no picture or sound. approx. price for this fix? any help is appreciated. thanks
  • Anonymous May 11, 2008
    my proyetion tv turn off by it selve and i have not been able to turn it back on i can only hear this pich noise inside i have the power botton on in green color but nothing alse
Check high voltage power supply ,the sound its making sounds like high voltage leak
Posted on May 14, 2008
  • 4 Answers
Update software/firmware
Posted on Apr 28, 2008
    Champion:
  • 317 Answers
This could be a number of probs. needs to be ck'd by a tv tech can usually be repaired for a few hundred bucks suggestions..audio ic,convergence ic,signal board or power module..note these parts are pricey so trouble shoot to correct part. John
Posted on Sep 11, 2007
SOURCE:
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Heard a pop, tv went off, then doesnt come back on
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 23, 2010 | Hitachi 50VF820 Projection TV
Tv started to turn on, but shut itself off,and won't turn back on
Hi t taylor,
I am very sorry to hear of your husbands passing. In the unlikley chance you have the original reciept the service plan number will be printed there.
If no reciept call 1-877-968-6391 and a customer service rep will be able to assist you
If  they are unable to help come back to FixYa and I will help with repair advice.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 03, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Magnavox # 37MF231D
that depends on the value of the television and the cost of replacing the power supply and connections.
Most likely you have a short in your power supply or other connections causing the tv to protect itself by shutting down. You can check with our Repair Service lookup icon for a repair service near you.
Before you call them you may try unplugging your unit for 30 minutes or so and plugging it back in.
Jun 26, 2008 | Philips Magnavox 27MS343S 27" TV
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Dec 17, 2007 | Olevia LT26HVX 26 in. LCD Television
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
