Question about HP OfficeJet Pro L7580 Color All-in-One Printer
Copy memory on HP L7580
When I copy a document, this printer runs out of memory after processing only five pages. But it seems to have no memory problems when I fax lengthy documents. Any ideas how to address this problem?
    Genius:
  • 1,601 Answers
Sounds like you need to change your virtual memory settings or buy more RAM.
Here is how to change the settings:
I am assuming you use WINXP
  1. Click Start , right-click My Computer , and then click Properties .
  2. Click the Advanced tab.
  3. In the Performance section, click Settings .
  4. Click the Advanced tab.
  5. In the Virtual memory section, click Change . Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be about 200 MB, and should be higher than or equal to the recommended paging file size shown in the lower section of the dialog box. When you set the initial size, Windows reserves on the hard disk drive the amount of space you designated for virtual memory. The maximum amount allowable can be anything above the Initial size setting, but it should be at least twice the Initial size setting, as shown in Figure 2. Figure 2: The Windows XP Virtual Memory settings copy memory on HP L7580 - c00174885.gif
  6. Based on the information above, make any necessary changes to the Initial size and Maximum size settings.
  7. Click Set , and then click OK .
Posted on Nov 12, 2007
  • Thomas Christopher
    Thomas Christopher Nov 12, 2007
    here is figure 2
    try this and let us know if it worked for you, thanks
6ya staff
SOURCE:
Hp cm 1312 stopping after five copies. Is my memory too small?
Check what is the size of the documents you print, if the memory is not decent and documents big, it may clog the memory temporarily. Regards, Mike.
Jan 18, 2016 | HP LaserJet CM1312 All-In-One Printer
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Regards,
Sean
Apr 10, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I have network printer with scanner. Model is hp officejet pro L7580 printer. I installed a printer sucessfully but I want to use printer scanner. So how to install scanner & use it?
Hello!
In order to install your scanner, you need to print a test page. As you need to align the cartridges, you also need to align your scanner. See the printed alignment page for directions on how to complete the alignment process. Basically, all you have to do is put the test page in the scanner and press scan.
Mar 31, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have pictures on memory card that is now in my printer. how do i get them to my computer? this is a HP Officejet Pro L7580.
I take it your printer's memory card drives are not showing up as individual drive letters under My Computer? If not, you might need to reinstall the printer drivers, here:
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&tool=&query=Officejet+Pro+L758#N416
Once the memory card drives show up in My Computer, it's just a matter of dragging and dropping from one of the memory card drives to your My Documents folder
Feb 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Hp Officejet Pro L7580
it seems that page sensor is dirty, clean it with cotton.
Apr 24, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Will not grab documents
hi,
try this...
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time and while holding it, insert the power chord.
> a semifull reset would be done
> after that try to fax.
thanks and regards
agnel
Feb 26, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7580 SCANNING PROBLEM
The paging file size may be set to low.
Let me know if the 2 individual documents are fine....
O/s & microsoft office version.....
Dec 15, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP OfficeJet Pro L7580 Color All-in-One Printer Logo
65 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
