Question about Acer Aspire 3000 Notebook
My Acer Aspire 3000 has a blank screen
I turn on my computer, the screen that says Acer comes on and it gives me the option to press F2 and go to the setup. If I don't go to the setup it continues to show a black screen with an _ at the top corner for a second then it goes away and the screen stays black and does nothing. The only thing I can do is go to the setup and I can't find anything to make it come on normally on the setup.
    President:
  • 2,961 Answers
When you get in setup check the time and date and see if correct, if not; correct it and save settings and exit, then it should reboot. If the time is correct and date then you will have to reboot the system and keep pressing F8 while its booting, this will take you into safe mode, you need then to choose last known good cofiguration and hit enter, hopefully you should now get into windows.
Posted on Sep 05, 2007
  • YEHONALA PASTENES Apr 24, 2012
    I have tried everything the only obtion that allows me is f2 i cant use f8,f10,f12 nothing but f2
6ya staff
SOURCE:
No access to bios, no op system
Update bios. Check or replace cmos battery.
Mar 04, 2015 | Acer Aspire One 521 532H 533 D260 NAV50...
My aspire 5733 goes to a blank screen when i turn it on
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 04, 2012 | Acer aspire 5733z4851 intel pentium...
I forgot the password to my laptop acer
Hi junior 707
Try this solution to your problem.
Start your computer
1. Keep pressing "F1,F2 or F8" as the laptop computer starts.(Depending on your computer)
This will start the computer in Safe Mode.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me thumbs up
Sep 26, 2011 | Acer Aspire 3000 Notebook
When i turn on my laptop an acer aspire 3000 it powers up but the screen is blank
Try upluging it, remove the battery, then press and hold the power button for 10 full slow seconds. Then wait 1 minute, put battery back in, plug back in and turn on.
It should now come on and work fine.
Jul 22, 2010 | Acer Aspire 3000 Notebook
PC won't load settings - blue screen
Try pressing the ESC button during start up this will give you the option of going into safe mode from where you can reset your operating system to a previous time
Jul 04, 2010 | Acer Aspire 3000 3005WLMI Notebook
How do I restore my acer aspire 3000 laptop to factory settings, I dont have a disc?
Most acer laptops have a special recovery feature..
While starting up your computer, when you see the first acer screen, start pressing alt and f10 at the same time, over and over..
You may have to attempt this a few times to get it to work.. If you see the windows screen, it has not worked, restart the computer again, and keep trying.
If you get it to work, it will give yo an option to restore factory settings. which will reinstall windows and make the computer like new.
Keep in mind this will erase all your personal files and pictures so you may want to save them first.
Oct 30, 2009 | Acer Aspire 3000 Notebook
Turns on but wont go pass the startup screen
Try to put an operating system boot disk in your drive then turn on laptop.
When the screen says press any key to boot from cd/dvd press a key.If it is vista when you do boot from cd it will give the option in the lower right corner to repair-click on this-select repair startup option.if that fails try a re-install of your op sys.
May 31, 2009 | Acer Aspire 5610 laptop vista combo with...
ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
ACER ASPIRE 3000/5000 SERIES LAPTOP
Log on to your computer with safe mode
Steps
1. Start your computer
2. As soon as you see the first black screen when the computer starts , keep on pressing F8
You will see advanced options menu
Select " Safe mode with net working"
Now your computer will give you an option to log in with the administrator username
You need to log in with Admin and then goto control panel and change the password for your username ...
If this does not work then plz reply back stating the Operating system you have like windows XP, vista , 98 , 2000 etc...
Thanks and dont forget to rate!!!!!!!!
Jun 04, 2008 | Acer Aspire 3000 Notebook
I suggest you check the settings of your bios. Normally this happens if your Hard drive is unreadable. Change the settings of the boot function to first boot on Hard disk and try to disable all other bootable hardwares like CD or network card.
Hope this helps.
Apr 22, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3000 Notebook Logo
237 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
