Back to:
Tags:
Hakuba CT-8-GR Tripod
Camera Ball mount has loosened from Tripod body (by 2 users)
posted by kzarsky on Sep 05, 2007
A single nut secures the Tripod ball mount stub to the tripod body/legs. The problem is that the nut has loosened, even though it has a lock washer. I cannot fit ANY socket into the 'apex' of the tripod legs to tighten the nut. There MUST be a trick to it. I can post a picture if that would be helpful.
The Hakuba CT-8 is an extremely compact, lighweight tripod, and lacks any type of central shaft for vertical adjustment.
Thanks,
KZ
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by SixFive, posted on Apr 03, 2008
I have this same problem w/this same exact trip-pod! For the life of me, I can't find a way to get that screw tighter!
Can you Help with these Tripods problems?
Tripods
i want i ball robo-468 drivers its cd had misplaced ,can...
Tripods
Clip which prevents leg section separation is missing.
Tripods
when i was loading my tom tom 510 every thing wus fine...
Tripods
hey i have a PC Line webcam (PCL-300N) and i have lost the...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
