Question about Motorola Mobility RAZR V3
Can't hear through earpiece
I can't hear any calls through my earpiece - must use speaker phone "all" the time - not cool! Motorola RAZR V3
  • 3 more comments
  • Flooz Sep 09, 2007
    It ended up that I just needed to basically reprogram it (as it was when received) - live help at Motorola...it worked!!
    Thanks
  • Anonymous Feb 11, 2008
    Same problem, can't hear through the regular speaker, but speakerphone works fine, earbud works fine. fg
  • 852456 Feb 26, 2008
    i can't hear though the ear peace what should i do
  • majique Apr 29, 2008
    Sometimes phone only works via speaker other time it works fine. How do I get a software reflash without having to take my "out of warranty" phone to a service center?
  • Anonymous Oct 30, 2008
    i change the earpiece ribbon two times and it the same problem. i have to press speake to hear.
    New Friend:
  • 53 Answers
If the phone is under 1 yr old I suggest finding the nearest Motorola service center as it is under warranty. If its not covered you could replace the speaker yourself, although would require a small amount of soldering or replacing the entire LCD module which could be expensive. Let me know if you decide to give it a try I can help w/ disassembly. Good luck.
Posted on Sep 09, 2007
I have difficulty hearing the other voice from the other phone call
It is possible that your earpiece is faulty and needs a replaccement. Clean the set in the area of the earpiece to clean the pores.
If this wont improve change the earpiece speaker with the same type .
Sep 12, 2010 | Motorola Mobility RAZR V3
My screen is black i cant hear who im talkin to but they can hear me i cant access my speaker i have a motorola razr v3
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
On the other hand, you said you cannot hear the person you are talking to, the problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jul 22, 2010 | Motorola Mobility RAZR V3
Cant hear incoming voices unless i put it on speaker. Can hear rings and all phone bells and whistles though. just not earpiece volume for incoming calls unless on speaker
this sounds like a broken earpiece speaker you might be able to find a replacement one on-line and replace it or if its still under warranty send it back in and get it replaced
Sep 25, 2009 | Motorola Mobility RAZR V3
My motorola v3 razr cell has no sound thru earpiece cannot hear unless you turn on loud speaker help please
That means your earpiece speaker is out. It could either be damaged or just dirty. The easiest way is to file an insurance claim. But if you are good with electronics you can take it apart and replace the speaker. However on some of the V3 models the earpiece speaker is a part of the LCD and cannot be individually replaced.
Feb 03, 2009 | Motorola Mobility RAZR V3
Incoming call
Seems your ear speaker has a problem. It need to be changed.
May 27, 2008 | Motorola Mobility RAZR V3
Can't hear when the speaker is off
earpiece and speaker are separate so in that case the earpiece is broke and u sould have'it replaced to a cellphone service
Apr 21, 2008 | Motorola Mobility RAZR V3
Auto bluetooth problems with Motorola RAZR V3 cell
don't think so.
maybe while pairing up the new phone you have turned down the volume on the earpiece?
Nov 28, 2007 | Motorola Mobility RAZR V3
Can't use earpiece...? (Motorola Razr)
Have you raised the volume while you are on a call as this is the only way the ear piece volume increases.
If this doesn't work then I'm affraid you have a faulty earpiece
Nov 06, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 - no hearing sound on ear speaker
Check the middle button on the side. Hold it in and raise the earpiece volume to the highest before you throw the phone away.
Jun 17, 2007 | Motorola Mobility RAZR V3
Its calling but i cant hear anything
Earpiece gone. wen u try 2 ring out put it on loud speaker if it works on loud speaker then ur earpiece has gone
Jan 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
268 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
