Question about Motorola Mobility RAZR V3
Bluetooth won't switch on
When trying to turn the bluetooth on the message "bluetooth connecting' appears but nothing happens.
    Brigadier General:
  • 7,752 Answers
Master reset the phone if that does not work have them reflash the phone's firmware , you can have that done at any mobile service center or by a professional mobile technician in your area.
Posted on Feb 23, 2008
SOURCE:
Need to connect to my I pad
What are you trying to connect?
If it's your Mobile:
On the Phone:
1. Select the option to enable Bluetooth Tethering.
2. Enable Bluetooth on the phone.
3. In the Bluetooth menu, make the phone discoverable by tapping the top message.
On the iPad:
1. Turn the Bluetooth on in Settings.
2. When the phone appears on the list of devices, Tap to connect.
That should do it.
Jan 12, 2018 | Computers & Internet
I have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
I got a problem regarding the message that appears whenever I try to turn on my bluetooth it says, "Turn on the WIRELESS switch on the VAIO etc..." Please help. Thanks
Well I assume your wireless switch is on, so it does sound like a hardware problem with the switch. I know it sounds funny, but try jiggling it. Worst case would be to send it in and have them replace it.
Jan 25, 2013 | Sony VAIO Y Series Notebook VPCY118GXBI
Hi guys. I'm new here. Hope i get some help, since i can't reinstall properly my Vostro 1015. Here's my configuration: Vostro1015 with Core2Duo T6670 @ 2.2Ghz, 2GB DDR3, 320GB HDD, Win Xp...
It sounds like the bluetooth device is turned off.
Go to device manager and look to see that the bluetooth is listed and enabled.
I hope this helps.
Good luck and have a pleasent day.
Jun 22, 2011 | Dell VOSTRO 1015 T6570 21G 2GB 160GB DVDRW...
I click 'turn adapter off' on bluetooth icon in task bar and now i cant transfer using bluetooth anymore. when i try to send file using bluetooth, message appear like this "bluetooth device not found....
you was torn off your bluetooth, go to control panel> bluetooth device and you can enabled your bluetooth device tthere
or use shortcut key Fn+F3 to turn on or turn off your bluetooth device
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Acer Aspire One PC Notebook
Can't turn bluetooth on. If I restart the phone and then turn on bluetooth, I get a message "Switching On Bluetooth" but it doesn't turn on. After that, nothing happens when I select "on", not even the...
Set up a Bluetooth connection
Select Menu > Settings > Connectivity > Bluetooth and take the following steps:
1. Select My phone's name and enter a name for your phone.
2. To activate Bluetooth connectivity select Bluetooth > On. indicates that
Bluetooth is active.
thanks
May 16, 2010 | Nokia 6301 Cellular Phone
Please anyone solve my problem?
this problem generally occurs with blue tooth devices.
before reinstalling device driver
  1. shut down your system properly
  2. turn on your system.
  3. turn on the switch of bluetooth
  4. now try to reinstall the driver
  5. after installing driver restart your system.
Apr 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
Nokia 6280 bluetooth
sir,u try by going to menu>>settings>.connectivity>bluetooth>bluetooth settings>>bt visibility>>shown to all then restart ur phone after restoring handset then try to turn it on..else there is a fault in handset regarding bluetooth function.
Oct 14, 2007 | Nokia 6280 Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
