Question about Sony Ericsson GC83 (797553009054) Modem
Touch pad sensitivity
After installing my GC83 my synaptics touch pad on my dell inspiron 8100 / win 2000 prof. becomes unstable and uncontrollable during transmit and receiving. I have discovered this problem exists on my alternate hard drive set up with windows ME and also XP - suggestions?? FYI - I am using the supplied antenna with my gc83.
2 Suggested Answers
SOURCE:
SOURCE: SONY ERICSSON GC83 MODEM NOT COMMUNICATING
network pin code for gc83 sony ericsson ?
Posted on Jan 21, 2009
I can not get my scroll bar to work on my touch pad, Dell inspiron 6400. How do I get this to work?
Try to load the "Touch-pad" drivers. Copy and paste the following link into your internet browser:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=22&l=en&s=dfh&os=WW1&osl=en&SystemID=INSPIRONI6400/E1505&catid=-1&impid=-1
Click on " input device drivers" and download the "Synaptics-Driver".
Feb 16, 2011 | Dell Inspiron 6400 Notebook
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
Dell XPS M1530 Vista originally installed - Fresh installed Win7 and now touch pad does not work - the right button works, and sometimes the left, but the touch pad does not. I've install the latest...
If you've reinstalled the drivers for the touchpad, the issue is likely the hardware- if in warranty, contact Dell tech support- if not, you may need to purchase the palmrest assembly and consult support.dell.com for the install instructions
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 24, 2010 | Dell Inspiron 1545 Notebook
I have aDell Inspiron laptop. How do you use the touch pad to drag. Why doesn';t tapping work for me?
ok.. it is as easy as visiting any download site of your choice e.g isohunt or thepiratebay, and search for [ Synaptics Touch Pad Driver-14.0.11.0] for download...install it and enjoy...
Jul 22, 2010 | Dell Black 173" Inspiron 1764 Laptop PC...
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
Cannot find synaptic touch pad sensitivity control using dell studio 64 bit windows 7
have you tried running as Administrator, and/or compatibility mode for XP SP 2, is digital driver signing, disabled at every bootup via F8? Is you .net framework up to date?
Feb 17, 2010 | Dell Inspiron XPS M140 Notebook
The scroll on my touch pad won't work i have an
you will need to install your Synaptics driver. Use the Driver disc that came with your DELL or you may download the driver at www.support.dell.com.
Here is the direct link to download :
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=17&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INSPIRONI6400%2FE1505&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Nov 12, 2009 | Dell Inspiron 6400 Notebook
How do i enable my laptop touch pad
Click the buttor or if you use windows go Start -> Control panel -> Mouse -> Synaptics and enable your touch pad.
Aug 08, 2009 | Dell Inspiron 6400 Notebook
Inspiron 1525 Touchpad has a mind of its own
I have had the same problem.  This may sound strange, but try the following:
Switch off the notebook.
Remove the battery and keep the on off switch pressed for >5 seconds.
Replace the battery and start the computer again.
The problem should then be resolved.
Mar 19, 2009 | Dell F3534 Touchpad
Sony Ericsson GC83 (797553009054) Modem Logo
51 people viewed this question
Top Sony Ericsson Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
