Question about Whirlpool ET0WSRXML Top Freezer Refrigerator
Cleaning my whirlpool refrigerator
I cannot remove the shelves. The last time I tried it broke. How do I clean under the shelves?
5 Suggested Answers
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
  • 8197 Answers
SOURCE: maytag refrigerator MSD2454GRW shelf removal
To remove the shelf lift the back up some and pull shelf straight out.
Posted on Dec 17, 2008
  • 8197 Answers
SOURCE: Trying to remove the water filter and front grill
To change the filter rotate counter clockwise. To remove the grill at bottom grab bottom lift up and out. also here is the manual.
Good Luck and please rate FixYa!
Posted on Apr 11, 2009
  • 1099 Answers
SOURCE: My Whirlpool refrigerator is leaking and water is
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Hope this helpout,
Posted on Jul 28, 2010
  • 2187 Answers
SOURCE: Every 12 hours or so
When defrosting, were you able to check the back of the unit inside if the panel accumulated ice? You may need to unscrew it t check the back side. Sometimes the water or ice comes from that area. Check also of the thermostat located in that area may have been frozen which sends a wrong reading to the control unit. When you have cleaned the unit make sure you have cleaned the drains for debris. It may also be a problem with just the drain which sends water into the tray underneath. It may not be aligned.
Posted on Apr 10, 2011
0 characters
1 Points
Shelf lock removal on ref shelves
open lock on one side remove then slide shelve to the side to release
Apr 07, 2014 | Dometic Refrigerators
How do I remove shelves for cleaning an lg French door refrigerator?
On my Kenmore (795.7555* made by LG) French door, the adjustable shelves are removed by tilting them up and then bringing them forward. The sliding shelves and drawers just pull forward.
Which model LG refrigerator do you have? There may have been design changes between your fridge and mine. Please add a comment with the information for specific instructions.
I hope this helps.
(I didn't bother to give the full model number of my fridge since the directions also apply to the 795.7519* and 795.7554*)
Jul 06, 2012 | LG Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The plastic drawers and shelves on my frigdaire break very easy
lube plastic with silcone spray after cleaning . the clips can be orderedfrom whirlpool or any parts dist. hope this helped mm
Dec 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refrigerator is not cooling enough.
You will need remove the screws in the back of the freezer section, check to see if the little fan is turning, if not you will have to replace the fan motor, this is what circulates the air and keep the fresh food side cool.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Spill proof shelves
well i cant find any service bullitens on the issue most of the time spill proof shelves slide out and in for cleaning have you tried to push them to the back
Jun 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Cleaning Glass shelves mold.
the shelves can be removed not taken apart. sorry they're glued together, just use a bristle brush and some bleach. no problem.
Mar 30, 2008 | Refrigerators
Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
Nov 17, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
Whirlpool top freezer leaking into refridgerator.
Sounds like you need to clean the drain again.. if Im understanding right you fixed it once already and lasted 3 weeks.. sound like it plugged up again.. make sure drip pan under evapurator is clean
Sep 24, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Whirlpool ET0WSRXML Top Freezer Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
