Motherboards
Problem for Motherboards
Generic problem for all Motherboards
I have ATC-1411B motherboard of AM4...
By rowadauto on Apr 06, 2009
I have ATC-1411B motherboard of AM486DX4 S 100 processor,
I want the manual of this motherboard to check the jampers setting, because my problem is, after the motherboard works some minutes (approximatly 10 - 12 min) the device begun give mistake, considaring the the processor has heatsink and fan, SO may be the setting of jumpers or bios setup need re setting specially the clk of bus of CPU and ISA BUS and etc..
So please advice me.
Thank you
Comments:
Apr 08, 2009
- My problem is :
My motherboard ATC-1411B include am5x86 133 processor, with heat sink only, after running 10-12 minute the system run randomly, if you sense the processor you found it a Little worm ..!! (not hot) if you cool it by fit a small fan on it heat sink, the system return work correctly, but after a period of 20 - 25 minute, again the system run randomly, when you direct external fan to it, the system run correctly again, but if you close the case of the motherboard, in 5-8 minute the system return work randomly.
So please if it possible to help me, and sent to me the manual of this motherboard, to check its jumpers or CMOS setting, or you can suggest to me any solution yo Will found suitable.
May 10, 2009
- After several testing, I found the problem is in the UMC main chip in the motherboard, after 10-15 minutes from first running it become worm (littel littel heat...) at that time the problems happend, when I direct a fan on it, the problems disappear, but after a next time, the chip become worm again, then the problems appear again,
So this exactly what happend in my motherboard ATC 1411B,
taking in your consideration that I put heatsink on the UMC chip.
please guide me what I must do
Solution #1
posted on Apr 06, 2009
Somewhat Helpful)
Muchaco
Rank: Master
Rating: 90%, 5 votes
What kind of problem are you having after 10-12 minutes. Be more specific please so I may help.
It wont be a jumper that needs to be set. Jumpers dont all of the sudden get moved by themselves. If your system started getting errors out of the blue then, considering the age of your motherboard, the easiest and cheapest thing to do first is change the battery on the motherboard that helps your CMOS keep the bios settings. If you are getting errors because of bios settings changing it may be as simple as changing the battery.   With a motherboard that old you may want to first try the most easiest repair first.
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
My computer just quit (black screen). The monitor works OK. I removed the hard drive and it booted... (More)
Answer
Does the FSB 800 mother board only support Vista drivers? I would like to run windows 2000 or XP but... (More)
Answer
how do i wire the on/off and reset button?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
