not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Was this helpful?
Yes
No
Popular Solutions for Zanussi ZJD1219 Front Load
Zanussi ZJD1219 Front Load All-in-One Washer / Dryer
a tripswitch went in my fuse board while my washer was mid-cycle. i flipped the fuse switch back on,...
(More)
a tripswitch went in my fuse board while my washer was mid-cycle. i flipped the fuse switch back on, but now the washer won't start another cycle... any ideas?
The belt connecting the motor to the drum of my Zanussi 1219 Washing Machine keeps coming of. The...
(More)
The belt connecting the motor to the drum of my Zanussi 1219 Washing Machine keeps coming of. The belt has not snapped and doesn't seem to be badly worn (though I'm not an expert so don't know)! Should I buy a new belt and how do I ensure that I replace the belt properly if this is the problem. Cheers, Colm
i have a zanussi washer/dryer it washes fine but when you put it on dry it drys for about 15 mins...
(More)
i have a zanussi washer/dryer it washes fine but when you put it on dry it drys for about 15 mins then e20 comes up if you switch it off and start again sometimes it will dry without stopping :( someone please help......................................?
My fabric softener compartment dispenses, but fills up with water after every load. Any solutions on...
(More)
My fabric softener compartment dispenses, but fills up with water after every load. Any solutions on this?
My Zanussi Diplomat APM8702 will not start. When the 'on' button is pressed the red 'on' light...
(More)
My Zanussi Diplomat APM8702 will not start. When the 'on' button is pressed the red 'on' light flickers but will not fully light up. Someone on the message feed mentioned replacing the circuit board but doesn't say how. Any ideas?
