How to set up Wireless connections
Computing for Dummies. Hi I need an indepth explanation on how to connect to WIFI on a Toshiba Satellite Pro 6000 series. It has an Integrated Wireless Lan apparently. I have checked this and it is correct but I cannot connect to it. Can someone explain in detail what I need to do/have and how to go about connecting. This is a secondhand laptop that i have just bought off Trade Me (NZ)and I don't know anything about the Wireless side of it. When I click on the Wireless Connection icon in the System tray it says "No Wireless Networks were found in range". If I go to set up it asks me for a SSID network name. Also on this page is a button that says - Automatically assign a network key (recommended) Next page says - Use a USB flash drive (recommended) or Setup a network manually It also tells me something about the Firewall not allowing the connection???? Please help. Cheers Dummy # 1
    Problem Solver:
  • 8 Answers
When your machine says no wireless networks found in range, your internal wireless is turned off or you are not physically in range of a wireless transmitter. If you have a wireless router that is transmitting or you know for sure that you are in range of one, then look to make sure your internal wireless in turned on. Usually, your machine will have some light on, likely a blue one, that indicates that your wireless is working. These are usually turned on by a small switch located on one of the sides of your laptop or by using the fn button along with one of your function keys (F2, F4, etc,)
Posted on Jul 30, 2009
  • 12,061 Answers
You have to have the "Other Half" so to speak... wat ya missing is someone else to connect to... Usually one ALSO has a WiFi Router OR connect to an "Access Point" both of these provide a WiFi Signal that can be accessed by your Wifi. blow are a couple of helpful links. To help you set up a home network. www.techtree.com/India/Guides/ Setting_Up_a_Wi-Fi_Home/551-74315-560.html www.microsoft.com/.../resources/technology/broadband_mobility/ hooking_up_with_wifi_6_things_to_know.mspx
Posted on Sep 05, 2007
SOURCE:
Restore FN + F8 key to reactivate Wi-Fi on Toshiba Satellite L500
My laptop didnt enable the wifi with the fn+f8 key.
I even reset the cmos and nothing.
Then I went to toshiba drivers website and after installing the "thku" "toshiba hotkey utility" the fn+f8 start working and enable/disable the wifi. It now shows a popup windows when I press the fn+f8 key.
Before the wifi led was always off. Windows detected the wifi device but nothing on the wifi available list.
Now the led is always on, starts orange when I turn on the pc and blue when connected.
Oct 05, 2012 | Toshiba Satellite L500 Series Notebook
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
Is this laptop is wifi ready?
Yes it is wifi ready.
click me for more info
Toshiba review unit had the following specifications: Intel Core 2 Duo T8100 2.1GHz processor Intel X3100 Integrated Graphics 2GB RAM DDR2 15.4" WXGA 1280x800 screen Intel PRO/Wireless 3945ABG (802.11a/b/g) 10/100 Ethernet LAN Modem port VGA-15 pin DVD-SuperMulti drive (+/-R double layer) supporting up to 11 formats Headphone and microphone jack webcam Battery: 6-cell (4800mAh) Lithium Ion battery Weight: 5.7lbs
Sep 15, 2011 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba Satellite Pro 6000. The wireless LAN was working ok till some snow got onto the back of the pc. The PC boots up ok but cannot find any wireless network. The Wireless led on the front panel...
The internal wireless cards of these laptops are underneath the keyboard (remove the plastic strip above the keyboard, then 2 screws holding down the keyboard, then remove the Torx security screw holding the WiFi cover). See if the snow job might have gotten to it and perhaps corroded it? The stock WiFi card is an Agere MPC-13a/20 (MPC-13a/20R) model - widely available on eBay for $10 or less.
If it's too troublesome, a wireless card that plugs into your PC card slot is probably the cheapest solution.
Dec 01, 2010 | Toshiba Satellite Pro 6000 Notebook
Toshiba satellite pro 6000 power
Sounds like a bad motherboard to me - assuming that it has memory installed.
Nov 29, 2009 | Toshiba Satellite Pro 6000 Notebook
Does the Toshiba Satellite Pro 6000 have a
The Toshiba Satellite pro 6000 doesn't have a built in microphone as far as I can remember but it does have a microphone socket at the front next to the headphone socket. Both sockets are on the bottom left hand side left if looking from the front. The microphone one is the one on the left, if you look closely there are symbols next to each of the sockets, one looks like headphones the other like a microphone.
Hope that helps
Chris
Jul 03, 2009 | Toshiba Satellite Pro 6000 and 6100 14.1...
How to Reset BIOS Password Toshiba Satellite A135
Hi! In order to reset the BIOS password for your toshiba laptop, you need to bring the NB to the nearest Authorized Service Provider for Toshiba since only a certified Toshiba Technician can reset the BIOS Password. The technician will remove the jumper inside the laptop which is integrated on the motherboard and the BIOS Password will be reset. All issues regarding the BIOS Password are directly handled by Toshiba Authorized Service Provider.
Hope this helps!!!
Thanks
Sep 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Display problem
Dear H duke,
please download the driver for Toshiba Satellite Pro6000 from this URL:
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-Pro-6000/download/page,sh,31302,221,19,.html
maybe this will help you.
Takecare
Akshay
Feb 26, 2008 | Toshiba Satellite Pro 6000 Notebook
Computers & Internet Logo
299 people viewed this question
Ekse
Alun Cox
