Question about Sewing Machines
Brother XR-33 Help!!!!!!!!!!!!!!! my sister gave me her brother XR-33 to use.I am having issues in threading the unit has a hole so I can sew. HELP!!!!!!!!!!
  • 1027 Answers
Manual for Brother XR-46c
Posted on Apr 13, 2008
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: Brother xr-65
This happened to me too! Make sure your buttonholer isn't pulled down and locked in to where it's making the machine sew backward. That's what happened to me.
Posted on Apr 22, 2008
SOURCE: brother xr-65
I am a begginer on sewing and would like to know a book that can tell me how to set my tension for certian materials? where can I get this type information? I think I can figure out how to put things together but the tension is another matter :)
Posted on Sep 15, 2009
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Stitch length dial is stuck on SS
Likely broken threads wrapped around internal components. Have it prefessoinally serviced.
Jan 09, 2014 | Brother XR-65t Mechanical Sewing Machine
The bobbin on my Brother Xr 34 sewing machine won't catch Please help
try changing the needle
try a different bobbin
try turning the bobbin the opposite direction
make sure the bobbin is inserted correctly into the bobbin case
there could be something wrong with the hook and hook race
and the machine may need some adjustment
Mar 06, 2013 | Sewing Machines
try the brother website
Apr 22, 2012 | Brother Sewing Machines
How to fix the bobbin tension on brother xr-35. one minute it works the next it doesn't
Apr 04, 2010 | Brother XR-35
Brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Oct 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Brother xr-65
The manual is on brother,com
Mar 23, 2008 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
522 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
